Introduction: Mini Survival Kit
Picture of Mini Survival Kit
This is an Instructable on how to make a mini survival kit.
Step 1: Gathering the Supplies
Picture of Gathering the Supplies
Tinfoil - Cooking and Signal Material
Clippers - Remove Splinters and obviously clip your nails once in a while
Razor - Substitute for a knife
Step 2: Adding All the Things In
Picture of Adding All the Things In
First start by adding the toothpicks, razor and matches inside the money and roll them up and put it inside, put the bandage behind the money,  then add the alcohol swab on the side, add the clippers in front of the money, add the lint in front of the clippers, then lastly add the tinfoil like so. Then Close. Or if you want to add chapstick, unfold the foil cut it in half, fold and add the chapstick in front of the clippers then slip the foil between the swab and case.
Step 3: The String
Picture of The String
Using the Solomon knot or whatever it's called or if you need further help on the solomon knot you can view this video from TIAT
https://www.youtube.com/watch?v=Fvr4rb0X8rQ&list=TLiIUqBeyqsezhFKKNllCtJr-f1Qh2izGg
Step 4: Your All Done
Picture of Your All Done
Now Go Survive With This Piece Of Magic!!!!!!
Captain MacTavish (author)2014-04-10
I will be updating this instructable SOON! Found out that this kit absolutly SUCKS, so updating time!
Yes I agree.Check out my survival kit.
Mattakers (author)2014-01-06
And maybe an emergency Mylar emergency blanket. Keep warm in the freezing wilderness at night.
Thanks!
You're welcome. I would suggest a maxpedition beefy pocket organizer. A bit expensive so rugged and durable.
Mattakers (author)2014-01-02
I would suggest some changes:
-take out the nail clippers. It takes up too much space for how little it does
-a bit larger case. It will allow you to put more essentials in
-add a ferrocium rod. They start way many more fires than matches
-water purification tablets. Easy to use and purifies 1L of water
-a better cutting tool. Maybe a small pen knife
-para cord. Has many inner strands and and outer shell and is very useful.
-fishing kit. Can catch food.
-snare wire. Can catch food also
-sewing kit. For repairing tents or clothing
-bigger first aid kit. You never know what's going to happen out there.
Make these changes and the kit's a winner.
Thanks for all the ideas, they sound alot better than what I have in there!
About This Instructable
2,403views
35favorites
Bio: Hunting. Fishing. Survival.
More by Captain MacTavish:Two ways to Set Up Your Fire with Helpful TipsHow to Make a Fire with Wet WoodAltoid Survival kit!
Add instructable to:
