Introduction: Mini USB LED
Here I will tell you how to make a Mini USB LED using stuff you probably already have around the house, such as a ruler, and an LED flashlight. Since USB supplies 5 volts of electricity it makes it very convenient to power things from. Oh, yeah, this is my first Instructable. Please rate!
Step 1: Get Your Stuff!!!
First thing you want to do is gather your materials. So here is what you want to get:
One of those LED flashlight things that come in cereal boxes I used the one they put out for advertising shrek, OR you could go to Radioshack and get an LED there.
A wooden ruler (you need the metal strip that runs along the top)
Masonite or something else like that.
A resistor ~347ohm.
Super glue
NOTE: If you use the LED flashlight you have to extract the LED.
Step 2: Cutting and Grinding Down the Masonite
Take your piece of masonite and cut it to properly fit the USB slot. Then, using the rasp and sandpaper grind it so that it is a ton thinner and able to slip snugly into the USB slot, grind it down a little bit more after that.
Step 3: Gluing and Sandpapering
Now take out the metal stip from the ruler. cut it so that it is about the same size as in the picture. then glue it to the masonite (as seen in the picture). Then take some sandpaper and rub it on the metal strips, this will make it shiny and make it so solder will stick to it better (see second pic).
Step 4: Soldering Stuff
So now you finally get to solder, yey! Take the LED and look at it from the top, one side should be flat, that is called the cathode. take the piece of masonite that you glued the metal strips to, and solder the Anode (opposite the Cathode) of the LED to the metal strip on the left. now take the resistor and bend one of the leads so that it is horizontal and lines up with the bottom of the resistor, look at second pic. Solder the horizontal lead to the right strip, then solder the other lead of the resistor to the Cathode of the LED. You should be done!!
Step 5: Plug It in and Watch the Glowiness. (:
plug the masonite in so that the metal strips are facing up, and enjoy the magical glow of an LED. I found out that it looks cooler if you diffuse the LED look at this instructable Make sure to visit my website and forum.
My forum
    • Epilog Challenge 9
      Epilog Challenge 9
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    i got a question... is it possible to use an already existing USB plug e.g. out of a cord or a flash drive???
    Yes you can.
    If you use an old USB cable, cut of the other end, then you will see 4 wires.
    The 2 for data (Dont need for this) and 2 for power.
    You only need the Black/Red ones.
    The Red is the +5V, Black is -5V.
    or if you dont want to difuse as this will decrease the light you can cover the LED in hot glue which will give it the same kind of look and will glow the glue in dark.
    With my lovely Dremel the sanding didn't take many seconds=)
    you dont need a 347ohm resistor, just a 100ohm
    Glad to hear people like it!
    What s magnetite, or soemthing?
    i would really like to see a 347 OHM resistor!
    I just found out it looks a lot better if you diffuse the LED, I'll add that to the instructable.
