3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini Van De Graaf... M & M style!
Step 2Sphere, Pipe
Sphere, Pipe
I sanded the lovely paint job off of my M & M, punched a hole in the bottom and chewed it into a bigger hole (1", to fit the PVC pipe) using wire cutters. Definitely not a clean cut, but I hid my shoddy workmanship later under a halo of Gorilla Glue. Don't tell. Some nice tin snips would have been swell.
I cut a 7" length of PVC, just eyeballing the length compared to my rubber band. Longer or shorter, I didn't notice any info out there about whether the length of the belt (and therefore the housing) matters much.
I drilled a 1/4" hole through the pipe for the "bottom" roller, and a small hole near the top for the upper roller's "axle," made from wire hanger.
To make the top roller removable, I also drilled a bigger hole above the "wire" hole (on one side), large enough to admit the diameter of the finished roller (see step 3). I then cut a slot between the two holes, so the roller goes in at an angle, then snaps into place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:mcraghead(HumboldtMusic.com)
Singer / Songwriter, guitarist co-founder of HumboldtMusic.com Day Job: Pixel Pusher @ Humboldt County HHS
