Mini Water Pump
3,083
60
Posted
Introduction: Mini Water Pump
This mini water pump is made with tinkercad and the motor is from a broken mini drone
Step 1: Design the Blade
  • I make a disc with 16mm diameter and 1.2mm height (3 layers with 0.4 nozzle)
  • make a cylinder with 2.8mm diameter and 3mm height and place it at the middle of the disc
  • make an another cylinder with 1.2mm diameter and 5mm height and place it at the middle of the cylinder
  • For the blades i use the symbol ''( ''and i turn it to the right angle to look like blade
  • place them to the right place
Step 2: The Housing of the Blade
  • make a cylinder with 19.6mm diameter and 8.2mm height
  • make an another cylinder with 17.2mm diameter, 7.4mm height and place it 1.2mm from of the workspace
  • one more cylinder , 8mm diameter and 10mm height for the inlet of water
  • add a cube 11x8x7.6mm like the picture
  • add a cylinder 5mm diameter, 10mm length and place it 1.8mm from of the workspace inside the cube for the outlet of water
Step 3: The Motor Holder
  • make a disc 22mm diameter and 2.4mm height
  • make a second disk 20.4mm diameter, 1.3mm height and place it 1.2mm from of the workspace
  • add a cylinder 11mm diameter at the center of those two shapes
Step 4: The Housing of the Motor
  • make a cylinder 10.6mm diameter and 23mm height
  • add a second cylinder 9mm diameter and place it 1.2mm from of the workspace
  • add at the center of those two shapes a smaller cylinder 1.2mm diameter for the motor's shaft
Step 5: Print It and Build It
  • print the files
  • i paint the blade and the motor housing for more meterial's strenght
Step 6: Make It Waterproof
  • add some grace at the frond of the motor
  • add at the back of motor some hot glue
Step 7: Finish the Pump
  • add some instant glue carefully at motor's shaft if needed
  • add hot glue around the pump like the picture
Step 8: End
it work nice with 3v power supply
...and if you want.. Subscribe and Folow for more :)
THANKS
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
2 Comments
thanks a lot!
but it is not a brussless motor and i dont know how many hours it can work continiously
