Now I am making a Mini Xco2 wind-solar hybrid led garden lighting from junk that I can get easily,just for fun!
Remove these ads by
Signing UpStep 1Material prepairation
So let us see this insructable may be used to inform the mini gen:
DCextractor fan ;plasticblade from bigger extractor fan ;solar cell (from my son's fan cap);conducting wire;bad Computer hard discs; aluminum shell from switch power supply; pencil sharpener;
bad circuit pcb that you can get elecronic elements you need in this insructable AB binder;li-ion cell (16800mah); plastica box of hot pepper sauce ; wood board of pencil ;pins;
screws;some tools obviously good tool like Craftsman may offer efficiency and convenient done.obviously good tool like Zing laser machine may offer best looks done.
![c344e0c77f6c7f_4[1].jpg](http://img.instructables.com/files/deriv/F9Y/DT5I/GLHRYGYP/F9YDT5IGLHRYGYP.SQUARE.jpg)
![338e7f3484f412_4[1].jpg](http://img.instructables.com/files/deriv/FIK/K6ZK/GLHRYGYU/FIKK6ZKGLHRYGYU.SQUARE.jpg)
i used to get between 2 and 2.5 volt
i did make a turbine with two of these on so i could get the 3.5-4volt for the 2.4 volt battery pack that ran the dark detection circuit shown below
if i had the right transistor i would of used the joule thief thersion shown below
What is the left diode volt drop down it must be lower than the PN of the triode?
I think with good sun shine outside summer the power would last longer.
I used 2*65vma,2.4v or so solar cell.
parallel connection by joule thief.
Others.the wind turbine does not need pegs on back of bearing.The magnet attracts the moter iron core autmaticly.
i have alot of junk im a pc tech also
i think you might need a bigger tail because once that blade gets upto speed they is going to be alot of reverse force
Famous leader Mr.Mao zedong said: Only the results of practice can test the truth of theory!:-)
After some days i will post some videos.Just be waiting... :-)
Leds turned off at 22:00 now here.;It turded on at 17:00 or so.lasted tota about 5 hours without wind turbine function in cloudy winter day.
That is a big research.
There may be good ic to solve the circuit problem,with successful theories.
and we have used joule thief to light leds from earth batterys solar wind etc etc
i have friends who have powercuts oftern and go for days with out power so trust me we try every idea and the idea of a joule thief to charge batterys was dismissed about 300 pages ago of a 1000 page thread at 15 posts per page
the locngest we have recorded a unit working is 40hours plus
looks like you have some knoledge of the joule thief as the one you made isent normaly were ppl start
he was also dyslexic like i am
thats the website
http://www.overunity.com/index.php?topic=6123.14475
thats the thread
also on here is bedini motors and all sorts of other stuff
Confucius, an ancient Chinese sage, said, ""Is it not a delight after all to have friends come from afar! "
You are real friend from afar of mine and who reads this !
Merry Christmas!
a garden light of this sort needs to be easy use as little voltage as possible as you dont have alot to start with
i found out of all of them a solar panel and fan 10 a 1.5 volt battery that then runs the joule thief with upto 12 leds on can run for at least 10 hours and still stay in the ideal zone of battery discharge but i did find that 2.4 tends to work better with dark detection circuits
Results:
1.the solar joule thief circuit did charge the battery.
2.leds only turned on at night.
