3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mini air-powered pen gun
How to make a small pneumatic gun out of a pen. It can be pressurized over 100 psi and shoot small nails into wood. THIS IS DANGEROUS if you choose to make this I am in no way responsible if you injure your self shooting it or if it explodes while your pressurizing it.
*I didn't know this but someone has already done a better job of a pneumatic pen on spudfiles http://www.spudfiles.com/forums/pneumatic-pen-gun-project-t7858.html thanks to Surfguy21 for this info
Step 1Parts
Parts
For this project you will need a bic pen and another piece of tubing (I got mine from a mechanical pencil) that fits inside the front peice of the bic pen if you remove the ink cartrige. You will also need a Zebra mini mechanical pencil (got from staples) or an eraser that fits inside a bic pen and you can drill a hole through. You need a schrader valve (the ones used on bike tires), and a airsoft bb.
40 comments
Oct 30, 2011. 2:28 AMramicaza says:
wow really cool how you actually made it out of a pen. I had an old one made from a marker but the 4mm barrel crumpled at 170psi :D... lol i made a new metal one though, and posted that here.
Oct 29, 2011. 12:45 PMmafzal2 says:
And now I am grounded for shooting my brother with this gun.
May 28, 2011. 12:03 AMRehtes says:
dude nice blade
Jul 2, 2011. 2:15 PMThe Jamalam says:
stop spamming, nobody cares.
Apr 17, 2011. 4:59 PMimproyo says:
what do you glue the eraser to???? is in the ink cartige
Mar 1, 2011. 12:25 PMsabladask says:
see my instructable, i made a spring powerd piston bb gun.
good build
Jan 3, 2011. 4:40 AMDreistein says:
a mini pellet gun
Nov 4, 2010. 1:24 PMilpug says:
this is just a mini piston cannon. but very dangerous.
Mar 14, 2010. 10:19 AMeel laup says:
that is very clever can u make a pdf url so non pro members can download
Mar 12, 2010. 1:30 AMlemminggenocide says:
make six, put them into a cap gun cylinder XD that would be soo cool
Jul 13, 2009. 11:25 PMiTraceur says:
Erm, I'm probably confused with the drawings, but when you push the trigger in, wouldn't it fire and hit your finger? I know I'm wrong, so could someone kindly explain, WHAT THE HELL?!
Oct 21, 2009. 4:41 PMDELETED_madscientist167 says:
(removed by author or community request)
Oct 24, 2009. 9:44 PMiTraceur says:
Personally, i just like showing off, so freerunning.
But i admire and appreciate the dudes who actually put backflips and 10m jumps into good use.
Dec 27, 2009. 4:00 AMyeolddingdong says:
do you go to anger classes
Oct 25, 2009. 9:28 AMDELETED_madscientist167 says:
Oct 28, 2009. 11:50 PMiTraceur says:
Why do you hate freerunning?  And how the hell is parkour more 'peaceful'??
Oh, and i'm not american.  And, how old are you?
Oct 29, 2009. 1:23 PMDELETED_madscientist167 says:
Dec 18, 2009. 11:33 PMiTraceur says:
Ok, i'm not going to bother arguing with you about parkour not being a martial art.  But you didn't answer my 2nd question: how the hell is parkour more 'peaceful'?!
Jan 28, 2010. 3:42 PMabsolute zero says:
what exactly is the difference.....
and this is a simple co axial piston cannon. when you push the scrader valve it lets air out, the pocket of air behind the piston becomes less pressureized. then the pocket of air around the barrel pushed back the piston and takes the path of least resistance, out the barrel.
Feb 21, 2010. 2:46 PMabsolute zero says:
not sure why i didnt get a message about your response.
But i was just looking back at this because my co axial mini isnt sealing, but i just notices that it isnt what i thought....
I think ill use this design if i cant get my piston to seal, trying to remove a ball pump as my exhaust valve(i dont actually have a schrader atm) isnt working very well...
Jul 18, 2009. 3:20 AMlemminggenocide says:
I think the idea is that you push the barrel inwards, by gripping it on both sides with two fingers. In other words, you don't have to put your finger over the end of the barrel to push it inwards. hopefully this helps LG
Jul 20, 2009. 12:26 AMiTraceur says:
Nice name. Right. Guess that's why it's called a co-axial pengun then... It'd be 10 times better to have the button on the side though... TO THE WORKSHOP! Oh, hang on... TO THE PENCIL-CASE! QUACK!
Jul 21, 2009. 6:09 PMlemminggenocide says:
thank you. the name refers to my inept gaming skills .......... btw, good luck making the pen gun, I would like to make one, but I don't nearly have enough skill to do so. LG
Jul 23, 2009. 3:58 AMiTraceur says:
Meh, strike that side-button-pen-gun. Too hard to seal it off. Ok, new idea - you know those pens that rotate at the back, with a little mechanism in the middle that pushes the ink tube forward? Turns out they're really easy to seal off, and I've got a nice-looking one... BACK TO THE PENCIL-CASE! Oh, and relating to your pen-gun making skills (Or, rather, lack of), Who really cares? Is there anyone on this site who can say they studied for a degree in 'Pen-Gun Making'? QUACK! (iTraceur, PhD, D. Psych, PgMD)
Sep 30, 2009. 6:40 AMiloveairsoftstuff says:
good ible accept i didn't see where you got the 1st barrel from, the one that goes on the outside of the ink cartridge.
Sep 18, 2009. 3:56 PMBen Nguyen says:
OMB I think I'm gonna try this.
Jun 19, 2009. 12:49 PMMadBricoleur says:
which specific pencil did you get the "larger tubing" from? i wanna build this so bad....! awesome... faved
Jun 1, 2009. 4:57 AMWambotrot says:
I just don't get it.
Mar 5, 2009. 4:14 PMcyborgpigeon says:
i see what your saying. jrs is piloted from behind, while this is activated by a protruding out the front inner barrel. either way if you activated the shrader it would act just as jsr's. potato patato in my opinion, props for makeing it out of a pen. also, something like this could be modified into a rather more sinister auto injector. just saying, i dont really want to give that any more thought. cringe ick.
Feb 4, 2009. 7:50 PMjamiespark says:
really cool
Feb 3, 2009. 4:55 AMbob the builder #1 says:
JSR's pen gun is the same still though, cool
Nov 11, 2008. 8:16 AMSurfguy21 says:
Its called a co-axial pneumatic gun and the idea isnt his.jackssmirkingrevenge from spudfiles.com came up with the idea of making it small and like a pen.You should give credit to him and all the other people that came up with the co-axial idea.
Nov 13, 2008. 12:44 PMSurfguy21 says:
O I see how it works now and sorry if I sounded mean before.Its a realy cool and concealable little gun.
Nov 7, 2008. 8:39 PMAnarchistAsian says:
wow, very nice, but it could use a few things.... like a video of it working and more detailed instructions better quality pics but GREAT idea!
Nov 6, 2008. 11:22 PMhoshi_neon says:
this instructure is confussing... can u use the yellow box inside the pics ?
Oct 24, 2008. 12:18 AMcheeseboy says:
wow this is a new idea that I haven't seen before, I am definitely going to try this, good pictures too. Also it would be safer if you wrapped it in electrical tape so that if it exploded the shards wouldn't fly everywhere. 5.0!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:Jor2daje
