Mini But Mighty KNEX Gun
Introduction: Mini But Mighty KNEX Gun
Please do not bash this gun for being simple and small, That was my aim - to build a workable gun in as few pieces as possible. I also designed the gun by my self without the use of anyone elses instructable, If it appears very similar to another idea it is only a coincidence. I am not the kind of person that would take credit for others work. Thank you.
Here i have my Knex gun which i produced with 13 pieces including a trigger. It also requires 2 elastic bands and some masking tape is recommended.
With a thick + strong elastic band it will shoot white rods over a very impressive distance for its size.
Pieces needed:
3x 5 way yellow connector
2x 1 way grey connector
3x 2 way orange connector
3x Blue rod
2x white rod
1x green rod
Step 1: Part 1.
Build this part 1st:
Step 2: Next Is the Trigger
Adding the masking tape on the end the ram rod pushes gives a flatter surface and makes the guns 'action' a bit smoother.
Step 3: Some Assembly
Assemble the trigger and body you have build like in the picture. You need a 5 way Yellow connector to stop the trigger sliding off
Step 4: This Ones Easy
Adding a white rod on the underside like so stops the trigger from dropping too low when the Ram Rod is removed
Step 5: Triggers Band
Add the triggers elastic band like so. This makes sure the trigger drops automatically when the ram rod is pulled back.
Step 6: The Ram Rod
Super easy step here.
Step 7: Your Finished
Here is the suggested elastic band routing. And a picture of it cocked and ready to fire.
Enjoy the Gun.
Hope to get some feedback and ratings
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    meh, bit basic
    OK, but did you think about trying to make a true trigger? I saw one a bit like this a while back but it ahd a true trigger. I think it got deleted.
    I have never tried to make a true trigger (cant figure out how), even in my bigger attempts at guns. I may try in the future, thanks.
    OK, I will build this and make a true trigger for it, if it is good I will PM you with pictures!
