Miniature Bat Signal, Mk. I by bwrussell
Featured
The power to summon the Dark Knight in the palm of your hand! Ok, not really of course but it's still fun to pretend.
This is the assembly instructions and circuit construction for the Pocket Bat Signal Design I posted previous to this. If you haven't seen the design walk-through here's a brief intro as to what this project is.
Designed for the 3D Design Contest (10/2012) it is a miniature (roughly 3"x3"x4") bat signal that can be 3D printed. It is designed in such a way that all the parts, excluding the circuit of course, can be acquired with two free prints from Instructables (if and when that program runs again) so that anyone can build their own, even if you don't own a 3D printer. It has a crank to change the angle of the barrel and is fully prepped for a LED circuit. More details can be found at the link above.
EDIT LOG
2/6/13: New .stl files with smooth curves on Step 1.
Step 1: Materials and Tools
Materials
  • Printed Pieces - The files are attached below. You need Smooth_Print_Block, which is everything but the barrel, and one of either Smooth_Print_OldSchool_Barrel or Smooth_Print_DarkKnight_Barrel, which are respectively the classic logo barrel and the current era logo barrel. The only difference between the two barrels is the logo. The file For Print.zip are the CATPart files of the two barrels and stacked parts.
  • Super Glue or Model Glue
  • 1 power LED - You can of course use any color LED you choose but white or yellow fit the theme best.
  • SPDT Center Off Switch - I went with a toggle because that's what I had, and toggles are cool. The SPCO switch allows for a circuit that can switch between battery and mains power. If you only want one of these then use a SPST.
  • 9 V Battery Clip
  • 9 V Battery
  • 4x #8-32 1/2" Screws
  • Wire
  • Power LED Driver Circuit- I use Dan's Constant Current Driver. You will need:
    • 1x ~100k-Ohm 1/4 watt resistor
    • 1x 1+ watt resistor - The value of this resistor is set by (.5/LED Current). Mine is 1 Ohm, 1 watt.
    • 1x TO-220 NFET - A heat sink is optional but recommended if available.
    • 1x TO-92 NPN transistor
  • DC Wall Transformer (Optional) - Minimum current = LED current and must meet NFET or LED array voltage requirements.
  • Prototype Board (Optional) -  Can help organize your LED array or driver circuit.
Tools
  • Soldering Equipment
  • Screwdriver
  • Q-tip or Small Brush - This helps apply glue to tough to reach surfaces.
  • Fine Sandpaper
  • File - Round for reaming holes and standard for general clean up
  • Toothpick
Note: The original design was made for either a single power LED or 24 standard 5mm LEDs. This is why there are holes in the divider in the barrel. The single power LED is the only one discussed here because using multiple light sources prevents the projection from working. Using a power LED is not as daunting as it might seem but if you choose you can still use the standard LEDs.
EDIT (2/6/13): The old .stl files have been replaced with new ones that have smoother curves. Now the barrel's and various radii will be smooth rather than the segmented prints you see in my pictures.
jerjod says: Jan 26, 2013. 11:58 AM
Cool!
bwrussell (author) says: Jan 26, 2013. 12:53 PM
Thanks!
siouxsette says: Jan 24, 2013. 5:21 AM
you could line the barrel with tinfoil, it would augment the light outpuit, and help with the light peeking through, but then, the sign wont be projected correctly again!
you could print a parabola, and line it with foil in the next iteration, or, if it fits inside, use one of those halogen bulbs, carefully grinding the base to clear the actual halogen bulb and peek your led through.
as for the heat, I would use one of the thin southbridge radiators you can find on motherboards, scavenge it from a dead one.
to adapt it to your use, the method could be, drill the two holes for the led wiring, nail it to a plank of wood through those two holes, and, using the correct diameter holesaw, saw it to the correct OD to fit in your bat sign
once done, de nail it, polish it a bit if you wish, solder your leads to the led, put thermal compoud to the back of it, pull the leads through the holes, affix the led to the heatsink, and assemble to the underside of your batsign, as a backcover (you can plan the holes in order to use the radiator fins as wire routing)
If you dont like the color discreptancy, mask accordingly, and spraypaint!
bwrussell (author) says: Jan 24, 2013. 8:27 AM
Thanks for the feedback and suggestions! When I make the Mk.2 it will be reprinted because there are features that need removed (standard LED holes), revised (wire pass through, etc), and added (some of the things I mention at the end). Because of this I'll be able to incorporate some of the things you mention, like provisions for a heat sink, into the new model, with out drilling or cutting.
I have some reflectors for the LED I used but I think printing a parabola into the barrel, like you suggested, and then painting it with chrome paint is the most elegant solution. The one problem is that I'm trying to keep this as accessible as possible so any reflector features need to be easily accessible, or included in the print, and need to fit a wide variety of power LEDs.
If Instructables ever does free prints again I have already designed and modeled a lens that should focus and narrow the beam and bring the focal point further away. If the lens works (the biggest question is how well the transparent printed material will work as a lens) then a reflector may not be necessary.
As far as stopping the bleed-through on the barrel I think the next version will have thicker walls. Also the final product will be painted to look like an actual spotlight which will also serve to block some of the extra light. I didn't feel like taking the extra time and effort for something that is clearly a prototype. Besides it will help make the progression from prototype to final product clearer.
siouxsette says: Jan 24, 2013. 5:26 AM
http://1.bp.blogspot.com/-wZ17nqPJGBw/TgcAWAdrwuI/AAAAAAAAAkM/zjqmMUsEonU/s400/Halogen-Lamps1.jpg
those kind of lamps can provide the reflector to use in your project, and with a diamond, or an aluminium oxyde bit, and a dremel, you are set!
J-Five says: Jan 23, 2013. 4:18 PM
To the Bat Cave!!!
3tuxedo says: Jan 20, 2013. 6:17 AM
This is so awesome it almost hurts. Great job and write up.
bwrussell (author) says: Jan 20, 2013. 9:44 AM
Thanks. It's just to bad the free 3D prints have stop, at least for now, so you canl't build your own.
Sjoerd X says: Jan 19, 2013. 4:02 PM
Looks great, but in the items list you suggest that 24x5mm leds are also possible. Wouldn't that make "multiple shadows", causing quite a less distictive shadow?
bwrussell (author) says: Jan 19, 2013. 4:54 PM
Yes, essentially it wouldn't really project, it would only light up. The array was in the original design because I thought dealing with a power LED might turn some people off of the project but after completing it I will only have provisions for the single source in all future versions. Thanks for the feedback, I'm going to change it up a bit to make that clearer.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
