This little device is a fun tool for pranking your friends and coworkers. Every few minutes it emits a brief, high-pitched beep. The beeping gets annoying after awhile, but what is really frustrating is not being able to find it. If you choose a good hiding spot, it can take hours to figure out where it is.
Remove these ads by
Signing UpStep 1: Materials
Jumper Wires
3 Button cell Batteries (I used LR932 cells but other sizes will work)
Printed Circuit Board (RadioShack #276-159)
3-16V Piezo Buzzer (RadioShack #273-074)
100μF 10V Capacitor
555 Timer IC (RadioShack #276-1723)
1kΩ Resistor
4.7MΩ Resistor
Large Paperclip
Tools:
Soldering Iron
Dremel (optional)
Part Substitutions:
The values of the capacitor and resistors are not critical. You can easily replace them with capacitors and resistors of similar values. The only effect will be that it changes the time between beeps. See Step 2 for a better explanation.
The PCB can also be replaced with any other PCB with enough holes to fit all the components.
Visit Our Store »
Go Pro Today »
Thanks
:0)
Also you need to watch what 555 chip you are using some of them can not sing as much current as they can source some only will sink 10 ma this i got from off of the data sheet for one of the ones I used.
http://www.westfloridacomponents.com/IC559APE10/NE555N+555+Timer+General+Purpose+Single+Bipolar+Timer+IC+ST+Micro.html
or
http://www.westfloridacomponents.com/IC359/KIA555P+555+Timer+8+Pin+DIP+IC.html
Which values are R1 or R2? C1 is fairly obvious (it's the only capacitor on the circuit, between pins 1,2).
"Increasing the value of either the capacitor or the resistor between pins 7 and 8 will increase the amount of time between beeps. Increasing the value of the resistor between pins 6 and 7 will increase the length of each beep."
I made a correction to the description.
Especially if you put it somewhere around the bedroom where the victim goes crazy to its beep and can't sleep from it... imagine it shutting up every time you open the lights to search for the annoyance!
Did you just add it serial after the battery?
hatelove these things!
