Step 2: Make the burner box
Using an appropriate tool (Dremel) cut a rough opening about 1/4 of the tubing diameter wide and leave 1/ inch at top and bottom. This is the access door.
Using 3/8 inch tubing, make two hinge pivots ant are 1/4 inch wide. Flatten one side with a file than braze to the side near the opening that was cut.
Cut a small section of 3/4 inch tubing that is about 1/4 inch wider than the the section that is cut out of the body tubing. Curve this to match the curve of the body.
  Placethe 3/4 inch tubing over the opening of the body and mark the perimeter and index one side.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
