Miniature Cornucopia Thanksgiving Centerpiece
200
4
Posted
Introduction: Miniature Cornucopia Thanksgiving Centerpiece
If your family doesn’t do big Thanksgivings anymore, or if your big dining table has been replaced with a smaller table then this little project is perfect. A scaled-down version of a traditional horn a’plenty filled with seasonal fruits and flora. It looks adorable by itself, but it also doubles as a menu card holder. Everyone deserves a little bit of abundance!
Supplies:
Plus air-dry clay
Non-stick mat, palette knife
Wood skewers, straight pin
Craft paints, small paintbrushes
Thin green floral wire Round-nose beading pliers
Wire cutters, craft knife
Clear gel craft glue
Small paper diecut leaves
Step 1: Make a Cone Shape
Start by making a basic cone shape – roll out and trim a 6” half-square triangle of clay at about 3/16” thick. Roll the left point up to the top and press together, then roll the right point around to the back. Slide a palette knife under the clay to lift off your non-stick mat.
Step 2: Make a Horn Shape
Carefully smooth the seams together, pinch the back end closed and use your fingers to shape the cone into a horn. Roll a ball of clay to fit inside and poke holes in it with a skewer. The ball will fill the back end, help the horn keep it’s shape, and act as a floral frog when you’re ready to fill the front end.
Step 3: Add Some Texture
Add a basket texture around the outside with a skewer – make long vertical lines for the ribs of the basket and short strokes for the weaving.
Step 4: Shape and Let Dry
To help the horn keep its shape while the clay dries, curl and prop the back of the horn against a bottle with a cosmetic sponge and place a foam egg or ball inside the opening. After about 12 hours, carefully cut a slit in the center of the horn, down into the ball, then gently pivot the blade a little from side to side to widen the slit. Let dry thoroughly for at least another 24 hours.
Step 5: Make Miniature Fruits
To make a bunch of miniature fruits, roll several different small sizes of balls, from 1/8” to 3/4” diameter. The smallest work for cherries, medium size are good for apples or oranges. For grapes, pinch and roll the next size balls into oblongs. For pears, gently pinch and pull up one side of the ball. For gourds (mini pumpkins), press the ball squat and carve lines around it with the skewer. Also make several plain pea-size balls to use for filler, behind the nicer fruits. Poke a hole inside each fruit with a straight pin and let dry for 24 hours
Step 6: Make the Fruit Stems
To make the fruit stems, bend short lengths of wire around the pliers and twist the ends closed. Pull the loop to oblong to mimic a leaf, or squeeze shut for a plain stem. Poke a stem into the hole in each fruit with a drop of glue and let dry. Arrange the grapes into clusters on top of a damp clay ball with a long wire stem, securing with a dab of glue.
Step 7: Paint the Fruit
Hold each fruit by the stem with pliers and paint. Paint the cornucopia and let everything dry
Step 8: Add Leaves
Glue paper leaves on to two short lengths of skewer and poke into the frog inside the horn. Poke the grape stems in the frog next. Fill most of the horn with the small filler balls, then add the fruit in front, gluing into place as you go.
Step 9: Add a Menu Into the Slot
After the glue is dry, place the corner of your menu card in the slot, if desired.
Enjoy your Thanksgiving Menu holder table decoration!
Designed by Lisa Fulmer
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
Great idea! My grandkids and I tried something like this with plasticine which failed due to operator error (2yr old smashing). Your design is elgant.
That's funny!! Thank you for your comments.
