Miniature Firearm With Easily Loaded Cartridges - The Snub
 by nepheron
This is my second miniature gun. See the first slide show for more information.
This gun is made entirely out of brass and solder except the handle, which is made of wood. It fires very small bullets that have quite a bit of power (see the video...) and is easy to reload.
This gun is about half as long as my first gun (the Hunter) and takes the same size cartridge. Accuracy is pretty good for something like this (you can actually aim at things!). In the video I shot the tube pretty close up, but you can shoot things at a distance with a little practice.
1-40 of 48Next »
shawntherobot says: Oct 4, 2009. 9:14 AM
finally i made it!!!!!!! i used an antenna fdrom an rc car for the gun and cartidges. now all i have to do is wait for my fuses to come in(i orderd them online).hurray great instructable
Ragnar_Svardfri in reply to shawntherobotOct 21, 2009. 12:43 PM
What did you use to cut your antenna?
I don't know what to use to cut it. I would borrow my dads dremel,  but he is out of cutting wheels.
shawntherobot in reply to Ragnar_SvardfriOct 21, 2009. 5:19 PM
to cut my antenna i just bent it back and forth ill it snapped. Then i used my pliers to open it back up into a circular form. You could probably just use a hacksaw if it was thicker if it is too thick my only other idea would be the dremel and buy some new cutting wheels. The inside barrel that doesnt move was already the right lenght when i pulled it apart from the rest of the antenna. But i have to buldanother one because it exploded when itried to fire it becuase i put in too much gun powder. will have to wait longer before able to post picture my camera broke while i was trying to make a video of it firing. Goodluck. ps dont put in too much gun powder.
Phoghat in reply to shawntherobotNov 2, 2011. 4:00 AM
Small copper tubing cutter (available at hardware or plumbing supply) will work
nepheron (author) in reply to shawntherobotOct 24, 2009. 7:10 PM
Yeah. Be very careful and start with a tiny amount and work your way up until you find the perfect amount.
Ragnar_Svardfri in reply to shawntherobotOct 21, 2009. 9:52 PM
I don't want to bend it back and forth and try to reshape it. I'll figure out something.
I'll remember that.
Ragnar_Svardfri in reply to Ragnar_SvardfriOct 22, 2009. 3:28 PM
I got it.
I drilled small holes through it almost all the way around, snapped it off, and filed it down.
i just realized that all the springs i have pushs out and I need a spring that pulls in. Well i do have some springs that pull in but they are from a trampoline so i don't think I can use that.
shawntherobot in reply to shawntherobotOct 5, 2009. 6:11 PM
ummmmm how do were do you put the pellets in the cartridge or do you put them outside the cartridge
nepheron (author) in reply to shawntherobotOct 9, 2009. 10:20 AM
They go inside, and are kept inside with a small piece of wadding.
Phoghat in reply to nepheronNov 2, 2011. 4:01 AM
instead of a fuze you might use a #11 primer for a black powder gun
shawntherobot in reply to nepheronOct 9, 2009. 2:31 PM
thanks (now i will be able to destroy all of my enemys)muhahahahahahaha!!!!!!!...............................................lol.........jk
nepheron (author) in reply to shawntherobotOct 9, 2009. 7:46 PM
Nothing more entertaining than shooting your enemies with minute metal fragments.
nepheron (author) in reply to shawntherobotOct 4, 2009. 5:13 PM
Sweet! I cant wait to see it. Thanks for the support!
shawntherobot in reply to nepheronOct 5, 2009. 5:31 AM
ill post a picture as soon as i can
Ragnar_Svardfri says: Oct 20, 2009. 9:55 AM
Amazing!
nepheron (author) in reply to Ragnar_SvardfriOct 20, 2009. 10:05 AM
Thank you!
Ragnar_Svardfri in reply to nepheronOct 20, 2009. 11:07 AM
I want to make mine out of an antenna. Will that work? And if it will do you know a good way to cut it without messing it up?
Phoghat in reply to Ragnar_SvardfriNov 2, 2011. 3:58 AM
Back in the 50s we used to call a gun made from an antenna a zip gun
nepheron (author) in reply to Ragnar_SvardfriOct 20, 2009. 1:44 PM
Askshawntherobot .
He made his out of an antenna.
Ragnar_Svardfri in reply to nepheronOct 21, 2009. 12:47 PM
I have a big box of fireworks in my garage. Could I use the fuses and powder from the explosives to make the cartridges?
nepheron (author) in reply to Ragnar_SvardfriOct 24, 2009. 7:13 PM
The fuses will work, but the fireworks are iffy (don't expect it to work. Explosions at this scale are hard to get with that kind of stuff). Just use 3 rounds of pop gun ammo. You know, the red ring caps in those kids' gun toys.
Missinthegrove7 says: Jan 12, 2010. 4:26 PM
is it safe to hold without burning your self
woodstockbirdy in reply to Missinthegrove7Jun 28, 2011. 8:23 PM
Probably, just the recoil on your fingers might suck
boomboy123 says: Feb 27, 2011. 8:30 AM
how do you make one btw i have subscribed to you
eggbert99 says: Feb 23, 2010. 1:36 PM
 loving your instructables. inspiring and creative. keep up the good work
Colonel88 says: Nov 29, 2009. 6:49 AM
Lol in the vid. Real pro would be to pierce it and the roll would still stand upright; like not move at ALL. My pneumatic crosman did that to styrofoam cups, but this is interesting.
nepheron (author) in reply to Colonel88Nov 29, 2009. 12:36 PM
The ammunition is very large (in scale) for the guns size. It's like shooting a marble out of a handgun. Quite a bit of surface area impact for this gun's size!
But if I used smaller ammunition... it might not pierce the paper.. :)
Kaelessin says: Sep 10, 2009. 10:32 AM
I must say that your projects are really inspiring . . . I made a pocket cannon and love that thing! I drafted up plans to make a miniature rifle with some modification on your mechanics and some strong deviations from stock design . . . I can't wait to put it together! Keep em coming man!
nepheron (author) in reply to KaelessinSep 12, 2009. 4:22 PM
Thanks for the support! My future projects may include: a pocket sized pinhole projector, 2 dollar zen garden, 5 dollar solar gadget charger, crystal radio, miniature Chinese medicine cabinet, micro-sized Japanese kites, homemade berry ink, making sea glass from recycled glass, and metal casting. Its great to hear you like what I do! Nepheron
zipzapper859 in reply to nepheronNov 16, 2009. 6:35 PM
you are really creative because i would really like to know how to make all those things. when you post the pinhole projecter please tell me because that would be soo soo much fun to have. just keep them coming and thanks
cowscankill says: Oct 25, 2009. 3:43 PM
Freaking amazing. I have been looking for something like this. Any chance on getting more details of the cartridges? or are they explained somewhere?
nepheron (author) in reply to cowscankillOct 25, 2009. 6:56 PM
That's great! I hope you are able to make one. Lurk around in the comments for a drawing of the cartridge. I'm pretty sure there is 2 diagrams floating around somewhere.
cowscankill in reply to nepheronOct 26, 2009. 5:13 AM
Awesome. Now I just need to find a store near by that sells assorted sized hobby tubes.
nepheron (author) in reply to cowscankillOct 26, 2009. 9:25 AM
Ace hardware will sell that stuff a lot. look around and be sure to ASK someone or you may miss it. The hobby tubing display is very small and often has stuff on top of it (signs, plastic, ect).
Ragnar_Svardfri says: Oct 22, 2009. 3:31 PM
Do you think i could make it into a shotgun by putting multiple smaller pieces of metal in the cartridge?
nepheron (author) in reply to Ragnar_SvardfriOct 24, 2009. 7:09 PM
Yeah, that's exactly what I did. It's very effective...nice spray of material. I recomend using sand for the shot. At this size, metal or sand will accomplish the same thing (sand is way easier to come by).
absolute zero says: Aug 24, 2009. 10:10 AM
did you make the cartridges? an are they reusable? and also, if i made one do you think it would be possible to hold it while firing?
nepheron (author) in reply to absolute zeroAug 26, 2009. 5:41 PM
The cartridges are aluminum and I refurb them after they've been expended. It's designed to be held. I don't hold it when filming because I'm trying to take a video and light it. Not enough hands! If you want some tube diameter information and a drawing, i could post it or comment it. Good luck :)
shawntherobot in reply to nepheronSep 16, 2009. 12:14 PM
oh ya whats the tiger balm for
nepheron (author) in reply to shawntherobotSep 16, 2009. 5:32 PM
Putting on scratches and pains. I use the tin for AMMUNITION!!!
1-40 of 48Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
