Introduction: Miniature HHO Electrolyser Torch for Work on Jewelry and Quartz Optical Fibers
Picture of Miniature HHO Electrolyser Torch for Work on Jewelry  and Quartz Optical Fibers
In hydrogen and oxygen combustion temperatures up to 2800 ͦC are obtained and that is used in science
for melting of pure materials because there is no contamination with soot.
There are commercial devices around used in jewelry and car repairs. Nice video about the benefits of using a hydrogen torch: https://www.youtube.com/watch?v=x07QDamYuec
In the present instructable H2 and O2 gas mixture is obtained by water electrolysis. It is an explososive mixture and should be immediately burned. A bubler and flame arrestor should be used. How explosive it is can be checked by filling just a few small soap bubbles in a plastic water cup and igniting them.
Video of the flame obtained in this instructable:
Picture shows melting one end of a 500 micron OD optical fiber made from fused silica. At these high temperatures the fiber end shines bright white color. It was possible to melt through thin metal sheets like razor blades. Welding of copper transformer wires was not successful as it requires more powerful flame.
Step 1: Test of Electrolyser Module
Picture of Test of Electrolyser Module
Electrolyser
Electrolyser module was bought from Ebay ”HYDROGEN GENERATOR HHO 21 PLATE DRY CELL” for 75 EUR. KOH solution in distilled water was used. The optimal cell voltage is 2 Volts and so 6 cells are connected in series to run from 12 V, and 4 groups are in paralell to increase production. Taking 12 V from a PC power supply caused it to shut down. Suitable option was a 12 V car battery charger rated at 4 Amps.
Bubbler
A 0.5 liter plastic water bottle with was used as a bubler to stop flashbacks. The cap has two holes for 4mm tubing sealed with hot-melt glue. One of the tubes goes way down to the bottom. Bubbler is filled with water almost to the top so that the exploding volume is small. Newertheless the bubbler vessel jumps up with a loud pop. Explosions are quite severe. Sometimes plastic tubes rupture. Fire is seen inside the tubes. Hydrogen burning heat energy is so large that water wapor gets heated-up to high pressure. Smaller tubes store less gas volume for explosion. A test can be done by filling a few small soap bubbles and igniting them. Safest way would be to generate pure hydrogen using a membrane separator for 200EUR from (http://hho.prom.ua).
Flame
Medical 4 mm tubes were salvaged from intravenous infusion system bought at drugs store. For the burner needles with outer diameter of 0.4, 0.6, 0.8 mm were tried. The speed of exiting gas has to exceed the speed of gas burning (~30 m/s) otherwise the flashback will occure. Sometimes needles get hot causing the plastic to melt and a wire mantle was wound on the needle to dissipate the heat. Best way to extinquish the flame was to put the needle into a cup with water.
Step 2: Construction of a Permanent Setup
Picture of Construction of a Permanent Setup
After a week or so an extra vessel appeared to be necessary to avoid soap
bubbles from entering the output line. Soap forms by dissolving of rubber seals and plastics. An enclosure from a 5’’ water filter was used. It is also holding extra electrolyte that is slowly used up.
Thick walls of the water filter enclosure allow to drill and tap holes for 1/4'’ and 1/8'’ thread diameter fittings. Threads were permanently sealed with anaerobic sealant. To cycle electrolyte bubbles efficiently 8 mm ID diameter plastic tubes were used.
Where just the the gas flows, a 4mm OD tubing with 1/8’’ fittings was used. An extra port was made where the water could be replenished with a syringe.
Anaerobic sealant was applied to the connections. Tightness was checked in a bucket with water. Soap bubble solution applied with a brush was used to check for leaks in assembled setup.
Step 3: Final Assembly
Picture of Final Assembly
A 2.5 bar max pressure gauge was used allowing to monitor if the system is
airtight.
A metal casing with a plenty of holes was built around the electrolyser to contain things inside during a potential explosion. On the buttom of the case was a plastic tray to accomodate eventual spills. An old PC fan cools the cell to reduce evaporation. LEDs allow to better see what’s happening inside.
The 220V to 12V battery charger was placed at a safe distance. On the electrolyser enclosure side wall was a power ON/OFF switch and banana connectors from the charger. Current was monitored by an analog meter measuring the drop voltage across ca 20 cm piece of wire.
Step 4: Ideas for Future Implementations
Picture of Ideas for Future Implementations
2’’ plastic pipes with screw connections as seen in many Youtube videos were not found in local hardware shop. May be drain water pipes can be used instead.
An extra water filter enclosure with a dryer filter can be used to clean up the exiting gas from KOH vapor that could be potentially corrosive. Test can be done by checking water produced after burning with a pH indicator paper.
Another feature would be to add electromechanical pressure relay like used in air compressors to cut the current. For example from Ebay ”AC 250V 1/4" Port Air Compressor Automatic Pressure Switch 1-5 Bar”. A gas flow meter can be installed electronic or floating ball type.
Step 5: ​Outlook
Hydrogen is becoming increasingly popular as a fuel. Hydrogen admixture during combustions helps to start engine in cold weather and engine can run on hydrogen indoors. Hydrogen is believed to improve the velocity of combustion leading to slightly higher gasoline combustion efficiency, cleans the engine from soot and allows easier start in cold weather, while disadvantages are electrolyte freezing and carbuerator explosion risk. Storing clean hydrogen in propane ballons becomes an increasingly popular alternative to batteries in photovoltaic systems. There s some medical interest to saturate drinking water with hydrogen that will make it’s electrochemical potential negative like that of the blood and body does not need to spend energy to convert it.
Step 6: Links
Benefits of Using a Hydrogen Torch:
Polishing Acrylic or PlexiGlass:
HHO Generator - Water to Fuel Converter:
Hhoconnection:
Homemade hydrogen generator and compressor unit:
Safely Making, Storing and Dispensing Hydrogen:
HHO Водородный сварочный аппарат 18-20л/мин
STAR-1000 Отопление Водородом 20 батарей:
Hydrogen on demand conversion kit. Turn any car into a Hybrid for only a few hundred dollars:
Assemble and Wire ER50 Brown's Gas (BG or HHO) Electrolyzer from Kit (upgraded):
A RESEARCH ORGANIZATION THAT DEVELOPS & DISTRIBUTES PRACTICAL ENERGY-SAVING METHODS & DEVICE:
http://www.eagle-research.com/cms/store/browns-gas...
H2-13B2 Pure hydrogen generator:
https://hho.prom.ua/p262202570-generator-chistogo-...
janisalnis (author)2017-09-10
Even more applications to try out:
+ Jewelry: rings, necklaces, decorations, dental prothesis, melting of stones and sand.
+ Soldering of electronics on pc-board.
+ Brazing (Silver Soldering) of air conditioner capillaries.
+ Welding of enameled copper wires used in electric motor and transformator assembly directly to terminal posts.
+ Welding and fusion of thermocouples.
+ Cutting glassfiber or carbon reinforced structures.
+ Sealing of glass ampules, lamps, reed switches, chemical glassware.
+ Heat shock breaking of diamond-scratched glass pieces.
+ Flame polishing of Plexiglas and Acrylic.
About This Instructable
1,637views
36favorites
License:
Bio: I am a researcher working on development of optical atomic clocks. Electronics is my hobby since childhood when my uncle was bringing me old phones ... More »
More by janisalnis:Traffic Lights Using Arduino Miniature HHO Electrolyser Torch for Work on Jewelry  and Quartz Optical FibersArduino Webservers Ethernet ENC28J60 with thermometer DS18B20, I2C LCD and Power Over Ethernet POE  for ZABBIX IOT data logging
Add instructable to:
