3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Miniature, cuttings-starting, white plastic greenhouse
Every once and a while, you may want to propagate plants you've taken from your own plants or grow new plants (eg from cuttings taken in the wild countryside -or- your neighbours backyard ;-).
In both cases, the use of a confined space (like a greenhouse) is mostly necessairy to obtain good results with most of the more fragile (usually non-indiginous) plants. This, to keep the air most enough for the cuttings to catch on and the rooting process to commence. See [http://en.wikipedia.org/wiki/Cutting_(plant) Wikipedia's Plant cutting page] for more information.
PS: when taking plant cuttings, make sure you have permission !
Objectives
-to build a durable greenhouse which has been proven to work in the field of plant propagation. The greenhouse uses a white plastic against overexposure by sunlight (trough possible overheating and/or dehydration). Similar-type greenhouses have been build by (semi-)professionals and this for the same purpose as used here (letting plant cuttings take root). As such, we can rest assured of the design and its ability to work properly.
-to decrease costs: it may not cost anything at all to build this greenhouse (if all parts can be obtained from the home), or atleast very less (when stuff still needs to be bought) This, given the materials used. The white plastic may be obtained from an agricultural company at a fair price and electrical (PVC) or flexible metal piping may probably be obtained at low cost aswell (usually even freely; try searching scrapyards, civic amenity sites, and/or try the freecyle network). The average brick or stone may be found laying around too.
-to reduce hassle: the greenhouse is compact/small and requires but a few and easily obtainable parts
Step 1Materials
Materials
Materials needed:
- 1 large, piece of milk-white (still luminous) plastic, sized to the length of the flexible pipes + 30 centimeter extra per side (to secure the plastic to the soil with bricks). Make sure you dimension your plastic to your own requirements. This is offcourse also dependant on the seed trays you use; (you may eg have 192 plant-spaces per meter if you can only put in one row). For our purpose, a 110 cm wide and 330 cm long greenhouse was made; but if you need a bigger one, refer to the drawings and go ahead.
- 5 PVC (or metal) pipes per 115 cm of plastic; for each extra 60 cm of greenhouse 1 additional pipe will be needed. Note that a 195 cm pipe will create a 50 cm high greenhouse with a width of 110cm (which is by btw locked into the soil 15 cm deep). Note that pipes will be set below and above the plastic to keep it in place. They will be held by a set of 2 pipes every 2 sections (or 120 cm; see next step) . This set of 2 pipes will be spaced above and below the plastic to keep it tight/dentless. Every section in between the sections with 2 pipes, a mere single pipe will be placed for the plastic to solely rest on. Look at the drawing below for reference.
- 1 brick per 80 centimeter of plastic
2 comments
Jul 25, 2008. 9:13 PMDeadpunk says:
nice job i might try this project come next spring i live in missouri and have no green house so unfortunatly year round gardening is out side my grasp
Jan 27, 2009. 12:46 PMplzspoilme25 says:
from Missouri as well i'm wonder how much of an early start we can get with this method. no way could start those tiny of babies on the ground this early, or even in a month from now
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:Green_Anarchist
