Introduction: Miniature Green House With Arduino
Requirements
- Soda bottle
- humidity / temperature sensor
- Servo motor
- Arduino
- box
- Arduino case
- elastic bands
- electrical wires
Step 1: Attach the Humidity / Temperature Sensor to the Soda Bottle
Attach the humidity / temperature sensor to the soda bottle with an elastic band
Step 2: Attach the Arduino Case to the Box
Step 3: Connect the Sensor to Arduino
in this case it is the AM2302 sensor
the AM2302 has the following wires yellow,red and black
Connect the red wire to the 5v slot on the arduino, connect the black wire to the ground slot (GRD) on the arduino. The yellow wire goes to a data slot on the arduino you select which pin in code later on, I used pin 2.
Step 4: Instal the Required Library for the Sensor in the Arduino IDE
http://playground.arduino.cc/Main/DHTLib
Download the library from Github and import the library in the Arduino IDE
Step 5: Write the Code for the Sensor and Test If It Works
U can use this code from the examples in the dht library to test the sensor
https://github.com/adafruit/DHT-sensor-library/blo...
Step 6: Connect the Servo Motor to Arduino
Connect the servo motor to Arduino the one I used had red,white and black wires.
Red once again was for the power 3,3v or 5v, black for the ground and white was for a dat pin in this case i used pin 9 like in the sweep tutorial of the Arduino examples library.
Step 7: Test the Servo Motor
To test the servo motor u can use the sweep example from the examples library in the Arduino IDE.
Examples -> Servo -> sweep
Step 8: Connect Both the Sensor and the Servo Motor to Arduino
Servo
red - 3.3v black - grd white - pin 9
Sensor
red - 5v black - grd yellow - pin 2
Step 9: Write the Code for the Green House
This is the code I wrote for my green house which ask for water if the humidity is below 50 %
copy the code and format it in the Aduino IDE so its easier to read (ctrl+T)
#include "DHT.h" // DHT & AM2302 library
#include // servo library
// Version number const float fVerNum = 0.03;
// Data pin connected to AM2302 #define DHTPIN 2
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); // LED pins
Servo myservo; // create servo object to control a servo // a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
////////////////////////////////////////////////////// // // SETUP // void setup() { // Setup serial monitor Serial.begin(9600);
//servo pin 9 myservo.attach(9);
// Wait 3 seconds delay(3000);
Serial.println(F("\nAM2302 Sensor")); Serial.print(F("Version : ")); Serial.println(fVerNum); Serial.println(F("Arduino - Derek Erb\n")); delay(5000);
dht.begin(); }
void loop() {
// Reading temperature or humidity takes about 250 milliseconds! // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor) float h = dht.readHumidity(); float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong! if (isnan(t) || isnan(h)) { Serial.println(F("Failed to read from DHT")); } else { Serial.print(F("Humidity: ")); Serial.print(h); Serial.print(F(" %\t")); Serial.print(F("Temperature: ")); Serial.print(t); Serial.println(F(" C"));
if (h < 50){ // if humidity is lower then 50 the plants should be waterd for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees { // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' } } else { for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' // waits 15ms for the servo to reach the position } } }
// Wait 3 seconds delay(3000); }
Step 10: Put the Arduino in the Case and Attach the Watering Indicator
Step 11: Put the Green House Over a Plant
Step 12: Done
The green house should now measure humidity and temperature.
If the humidity goes below 50 % the servo should turn putting the flag up indicating the plant needs water.
