Minimalist iPhone Wallet by FryGuy2086
Featured
I am a minimalist. I have a very thin and sleek card holder I use for a wallet, but at times, even that is too much. There are some ok options out there for carrying just the essentials (money clip, etc.), but nothing was quite right. Because I will always have my phone on me, I figured, why not make it my wallet as well.
There are such contraptions that merge the two, but most are large, many are a fold type wallet, and none are as versatile as need be. This is designed to hold anything including credit cards, business cards, cash, a notecard, or any combination of these.
You will need:
1.) A rigid or semi rigid plastic iphone case, ideally with a flat back. I used this one: http://www.incipio.com/cases/iphone-cases/iphone-4-4s-cases/iphone-4-4s-ngp-matte-semi-rigid-soft-shell-case.html, and it worked very nicely.
2.) 3/4" elastic strap (available at any sewing or hobby store)
3.) 1 1/2" wide aluminum sheet (1/16" thick)
4.) Band saw
5.) Utility or exacto knife
6.) Sewing machine or needle and thread
7.) A little bit of scrap fabric
8.) Fine grit sand paper (220)
Step 1: The Aluminum Sheet
The aluminum sheet serves as protection for the things in the wallet. I wanted to be able to put anything in the wallet and not have it get crumpled by the elastic or damaged while in my pocket.
To start, I measured the back of the phone case to see how long I could make it without interfering with the camera. Also, it had to be long enough to hold a business card. I settled on a length of 3 7/8" but you could make it a little longer or shorter.
Measure and cut the aluminum sheet to the desired length using a band saw with a metal cutting blade.
I did not want sharp corners, so I measured in 1/8" from each corner and cut off each at a diagonal.
In order for the aluminum to stay in place i notched it at the top and bottom of the long axis.
I measured in 5/16" from each side for the edge of the notch and cut the notch 1/16" deep, then used the band saw to remove the material.
Use sand paper to smooth all the edges and corners after the cuts are complete.
Radrussian says: Mar 20, 2013. 6:19 PM
Awesome Man! Made a spin-off and made the aluminum part out of flattened pvc. Thanks for the inspiration!
daemn22 says: Feb 18, 2013. 6:27 PM
Cool idea! You can also use old plastic credit cards and cut them to size instead of aluminum sheet for those who does not have machines to cut with.
gijoebob says: Jan 21, 2013. 9:37 PM
I use a similar case from Case Mate that holds my drivers license and my debit card. All the rest of my traditional wallet contents are in the phone.
Thraeryn says: Jan 20, 2013. 1:27 PM
Interesting. I like the idea a lot, and this seems a pretty good implementation.
I'm using an Android device that has NFC capability. I wonder how this would interfere with near-field signal. It'd certainly make the back of the phone a little less "near" than usual. I'd consider using a magnetic piece of metal if I didn't think it would stand a chance of zapping the magnetic strips on my cards.
Any thoughts, community?
making_hands says: Jan 20, 2013. 11:42 AM
I am sure you heard of the "Slim" wallet.
http://www.kickstarter.com/projects/supr/slim-the-thinnest-wallet-ever
DeltaD20 says: Jan 20, 2013. 11:22 AM
that's good to hear. How stretchy is the band when you sew them together? I assume how well the cards stay depends on how tight the band is.
now all I gotta do is how to alter the design for my Samsung S3
DeltaD20 says: Jan 20, 2013. 8:34 AM
been trying to do the exact same thing but w/ tape and clear sheet of thin plastic, works well for a month but the tape wears off. This method is better but like another user said, it can fall out quite easily due to the credit cards being so slippery. A good idea nevertheless and I will look into improving your design.
FryGuy2086 (author) says: Jan 20, 2013. 11:01 AM
I think you would be surprised at how firmly even a single card is held in. I considered adding some sort of a retainer on one side but once I finished it and experimented with it, it became evident that it wasn't necessary. I have been using it for about a week now and the cards don't even move much less come close to sliding out. Thanks for the feedback!
Gman2005cs says: Jan 20, 2013. 8:37 AM
What a beautiful Brittany you have! I have one as well.
FryGuy2086 (author) says: Jan 20, 2013. 10:57 AM
Thanks!
NateHoy says: Jan 20, 2013. 5:52 AM
This is very well done. About the only change I'd make, if I made one at all, would be to put some sort of retainer on one side so you reduce the chances of anything sliding out.
Clever, minimalistic, well-documented, nice clear photos and descriptions. Fantastic job!
Penolopy Bulnick says: Jan 16, 2013. 5:31 PM
Very nice way to keep everything together so you don't have a bunch of stuff fattening up your pocket :)
Penolopy Bulnick says: Jan 17, 2013. 5:18 PM
Also, you should enter this into the Holiday Gifts Contest!
c3ralki1l3r says: Jan 16, 2013. 5:55 PM
What if you lose your phone or it gets stolen D:
gijoebob says: Jan 21, 2013. 9:38 PM
What if you lose your wallet or it gets stolen?
c3ralki1l3r says: Jan 22, 2013. 4:59 PM
either way its still bad to lose one or another valuable item.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
