3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Minimalistic Desk
Step 2Work Horses
Work Horses
Work horses are a very easy and cheap solution for a desk, and in this case they are the main pieces of construction. I could bought some but I barely spend a dime building this two. This is what i did:
First of all keep in mind the hight of your desk surface, usually desk tops range from 27" to 30" , I use 29" for the top of my. I subtract the thickness of the panel 1-1/2" which gives me 27- 1/2" for the top of the horses. The length of the top piece (horizontal) is 28", the same depth of the door panel. I set back the legs 2 - 1/2" from the edges, (see note 1 in the pic).
Keep in mind the angle of the legs, which will be roughly the same as the hight 27 - 1/2".
For this I attached a piece of 1 -1/2" x 3/4" under the main runner of the bench between the two legs to get the angle. (see note 2). At the bottom of the horse I got 8 - 3/4" between the legs (see note 3).
Next I drill a 3/8" hole on the horizontal piece, at roughly 1 - 3/8" from the top , and also in the two pieces for the legs to drive the 3" machine screws, keep in mind that the machine screws are 1/4" dia, but the legs are in an angle, that's why we need a 3/8" hole to bare some room for the screws (see note 4).
When I fixed the hight of the work horse tighten the screws and every thing was in order I put two drywall screws into the 1 - 1/2" (the angle piece) to secure them, see images.
At this point the horses are still a little bit wobbly.
At the bottom of the legs I put a 7 - 3/4" piece from 2 1/2" from the floor to secure the legs, and also as support for the 2 last pieces of pallets (shelves).
When everything is in place and secure, the work horses were very stiff. From here the rest is very straight forward.
1 comment
Nov 22, 2011. 2:03 AMacoleman3 says:
oh....is the set back on the top of the sawhorse legs to keep the ends of the support rail from spiting out? i have a feeling they are.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:arte.sano
