Minion Log Burner
5,046
37
Posted
Introduction: Minion Log Burner
Minion log burner
Step 1: Locate Your Bottle
Find an empty gas bottle, if it's not full empty you can use a nail to expel the remanding gas. Once it's empty I use a hack saw to cut off the tap on top. Next fill it will water to dispel any remaining gas.
Step 2: Marking Out
Using a magic marker, mark out your design. I used a 100mm angle grinder and cutting disc to cut the holes and the door, cutting circles is tricky.
Before I cut the door I marked out, drilled and tapped my holes for the hinges, I find it easier to do this while the bottle is still in one piece.
Step 3:
Step 4: Hot Plate Hole
I wanted to make a hot plate on this burner and chose to use an old circular saw blade. Mark is out and get cutting. I used the grinder to remove the sharp bits on the blade.
Step 5: Assemble
I made the arms and legs from scrap steel we have knocking about at work. One of the arms doubles as the door handle.
I mock the whole thing together with masking tape before grinding and welding.
Step 6: Weld and Grind
I'm using a cheap £30 ark welder from Lidl which over heats in no time at all but whike it's cooling down I can grind off the slag and spatter.
Step 7: Paint
I used spray on stove paint for the minion. I have been told that automotive brake calliper paint might work, that way I could paint it minion colours.
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
