This project uses a die-cutting machine to emboss the background. But if you don't have a die-cutter you can use the traditional dry embossing method using brass templates, a light source, and a stylus.
Remove these ads by
Signing UpStep 1Gather supplies
Mint green cardstock by Paper Reflections - cut one piece to 4 1/4" x 5 1/2" and a second piece to 1/2" x 4"
Chocolate brown cardstock by Paper Reflections - cut one piece to 4 1/4" x 11" and a second piece to 1 1/4" x 4"
Stamps:
Express It magnetic stamp set from Making Memories
Ink:
Chocolate Chip from Stampin' Up!
Tools:
Magnetic stamp base set from Making Memories
1/8" hole punch
1/8" eyelet setter (I use the Instant Setter from Making Memories, which has exchangeable tips for both punching holes and setting eyelets in three different sizes)
Setting mat
Hammer (optional)
Stylus
Corner rounder punch
Paper trimmer (not pictured)
Big Shot die-cutting machine by Ellison Design (not pictured), or other die-cutter that is compatible with Cuttlebug dies by Provo Craft
Adhesives:
Your favorite paper adhesive (I used double-sided scrapbook tape)
Other:
Small white silk flower (hint: you can buy a bundle of silk flowers at many dollar stores, and then just disassemble them to get the flower off)
4 1/2" of white 7/8" wide sheer wired ribbon by Offray
Silver 1/8" snap (also called flat-topped eyelets) from Making Memories
D'vine Swirl embossing folder for Cuttlebug machine by Provo Craft
Thank you!
A REAL mint choc. chip card would be the awesomeness!
I personally love the look, and especially the feel of dry embossing. It adds a lot in my opinion, but this card would absolutely be just as great without it. If you don't have a die-cutter you can use the traditional dry embossing method I describe in my previous reply, but just using a stamped image would look great too. It would take a lot less time to make as well!
