3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Minty Boost Extra
Minty Boost Extra
A v. 2.0 Minty Boost I just bought from AdaFruit (very similar to the one in Lady Ada's Instructable except that it apparently works better with iPhones now). I used a larger Altoids-type tin, not the gum tin - that gives me room for a spare set of batteries. I also made the hole in the side without just clipping a notch. Nothing special really, but I hadn't really seen that so I figured I post it.
Step 1Making it
Making it
The Minty Boost is made per the kit instructions (available at Lady Ada's site). I wanted the USB port to be fairly flush, and I didn't want a big notch in the side. I had thought about using a Dremel to cut the hole, but after googling around a bit saw a mention of just using a hole punch. I put the minty-boost inside where I wanted it, then marked the outside with a pencil at the approximate location. It worked great - made 3 overlapping punches. Then I used a small file to enlarge the hole to the right size.
45 comments
1-40 of 45next »
Jul 31, 2009. 3:32 AMma3574 says:
I'm a complete newbie but could you not make another cut on he tin and then add a switch between the MintyBoost and the batteries so that they aren't drained. Thoughts?
Mar 19, 2012. 9:26 AMscottinnh says:
No switch was needed in the Minty v1 or v2, but in the Minty v3 circuit it seems a switch would help.
MAX756 quiescent current: 60uA
Linear 1302 quiescent current: 200uA
I use rechargables, but they are all Sanyo Eneloops (low self-discharge) and they remain nearly fully charged for months on the shelf. In a MintyBoost, they only last a few weeks even though the Minty has not been used any.
A Linear rep I spoke with claimed the Mintyv3 had "a direct path through the diode to the output when the part is in shutdown which will drain the battery" (I'm guessing this means the circuit lacks something necessary to automatically switch it into logic controlled shutdown mode, which the Linear spec sheet lists as 15uA... quite a lot less than 200uA!).
If any folks could confirm this or comment or suggest improvements (to take advantage of shutdown mode) that would be awesome. AdaFruit is really busy on new products and my sense (opinion really) is that new revisions to the Minty for problems like discharge are just not a priority.are not a high priority.
Apr 11, 2010. 6:49 PMyazug says:
around 2 years to drain the batteries if left plugged in.
Apr 12, 2010. 9:12 AMma3574 says:
 2 years that's really good life. Thanks
Feb 1, 2012. 1:16 PMthe dashing hero says:
ipod mini? you mean ipod nano?
Feb 8, 2012. 3:33 PMCofo says:
No, iPod mini is correct. They use to make them, though I don't know why they were discontinued.
Feb 14, 2012. 1:50 PMthe dashing hero says:
ipod mini isn't that mini
Jan 2, 2012. 3:21 PMbmondor says:
I just bought minty boost and when I finished assembling it I put the batteries into the battery pack and the boost converter chip heats up and gets really hot. Also when I went to see what the voltage was for the USB output it wasn’t get the 5v like it is suppose to. If you know what the problem is will you please let me know. Thank you
Jan 2, 2012. 7:32 PMbmondor says:
I tried soldering the 2 USB output together on one of my minty boost and the boost converter chip still heats up Are to older versions of Minty boost more reliable? If so do you know where I could buy an older version? Thanks
Apr 11, 2010. 8:02 AMyazug says:
from LadyAda's comments and analysis the drain is the same order of magnitude as that at which batteries discharge by them selves.
Apr 11, 2010. 6:48 PMyazug says:
Found link
http://www.ladyada.net/make/mintyboost/process.html
"That means that the self-discharge rate is ~2000mAh / 0.1mA = 20,000 hours, more than 2 years. Most batteries don't last that long! Therefore we don't need a switch, when nothing is plugged in, almost no power is being used."
Jun 1, 2009. 8:22 AMD4NG3RNL says:
You know what's the best about your little mod, the room you have left is great to store some additional battery's. in case the set that's in run dry!
Aug 9, 2009. 12:55 AMaarone_14 says:
or for some actual mints _
batteries is also good ;)
Feb 25, 2010. 6:32 PMkimball100 says:
you could get a larger batter try so it would charge faster
May 7, 2009. 7:11 PMmetalicaman8 says:
if you want the batteries to live longer just put in two packs of two batteries with each pack wired in series and the packs wired together in parallel. The batteries in series adds the voltages while wiring the charge packs in parallel allows the current draw to be evenly split between the charge packs, thus doubling the battery life span. You could then cut another hole in the side to add a switch to cut power if you are really worried about battery drain.
Feb 20, 2010. 10:14 PMjono456 says:
 If you are going to use 4 AA-cells the only way is to put all cells in series and completely eliminate and electronics to raise the voltage. That raising the voltage from 3 to 5 volts has a certain amount of waste (heat).
If you are afraid of the 6 volts you will get if using AA alkaline cells then simply put one or two in400x silicon diodes in series with the batteries to drop the voltage .7 to 1.4 volts. Very simple and the least amount of waste possible.
Don't over build, especially when it comes at a loss of efficiency. No switch will be needed. The cells will last their shelf life. If you are using NiMH cells (by far the cheapest solution) you don't even need the diodes. Just 4 AA cells in series and you have the perfect USB power solution with no undue waste.
Feb 20, 2010. 10:16 PMjono456 says:
 Above that should read 1N400x series diode such as a 1N4001, 4002, 4004, 4006.
Feb 11, 2010. 5:30 PMGreeneyedggirl says:
 Why not wire it up for four batteries and thus be able to have more power available in the extra space?  Just wire two in parallel that way the voltage stays the same, but the available power doubles?  This was you could use say for argument sake four 2300 mAh batteries to get an effective yield out of the little magic box of 4600 mAh?
That's what I think I'm going to do when I build mine.
Oct 25, 2009. 7:56 AMgreenie7888 says:
Hi, Nice Instructable. I was wondering if you could use the mintyboost v 2.0 kit and instead of putting spare batteries into the extra space if you could put in another battery holder and wire them in parralel to the minty boost circuit?
Thanks, Sam
Oct 14, 2009. 6:08 PMharmless matt says:
I bought three of the MintyBoost 2.0 PCB's, but I don't know what partsto get.
Is it the same parts as the Mintyboost 1?
I'd really appreciate it if someone could post a BOM.
Oct 14, 2009. 9:35 PMharmless matt says:
Thanks!
Jun 25, 2009. 7:47 AMsyphek says:
You might (not sure) be able to coil up an ipod connection cable an put it in the extra space?
Jun 1, 2009. 8:24 AMD4NG3RNL says:
Haha, I forgot to check out the last picture when I posted that reaction xD I made a micro USB charger hub (2 ports & some cable) that would fit in there snugly! (its about the size of 2 AA battery's so) Altho I'm not sure if this thing provides enough energy to charge 2 USB devices simultaneously
May 7, 2009. 7:47 PMsanguyen says:
So can you tell me how many ohms R4 and R5 are? I don't know where to solder the resistors so yeah can you please let me know?!
May 10, 2009. 1:05 PMsanguyen says:
Yeah I found the webpage that explicitly showed where to solder the resistors and what their values were after I had posted the comment. he he so yeah sorry about that and thanks for replying.
May 15, 2009. 8:01 PMsanguyen says:
Yeah that's true. Okay, thanks!
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:AleGuy
