Introduction: Minty Stove (Might Not Be the Best)
Picture of Minty Stove (Might Not Be the Best)
This is just a common sense thing for any flammable liquid so try not to criticize
(My first instructable all comment are welcome or any tips will be needing some)
Step 1: Materials
Picture of Materials
Quantity: 1 Altoids Tin
Quantity: 1 Rotary Tool ( I cant afford an actual dremel so i got a cheapo one but still works great [$20])
Quantity: ? Any flammable liquid ( I used 91% Denatured Alcohol)
Quantity: 1 Needle Nose Pliers
Quantity: ? Sandpaper (Depends)
Step 2: What to Do
Picture of What to Do
Its actually really simple
Get the Altoids Tin and either eat them or throw them out like I did (I got some bootleg ones and they taste like shit so I just threw em away
Step 3: Almost Done
Picture of Almost Done
With pliers go to the hinge where the lid is held on and they are just two little bent pieces of metal so use the pliers and bend till they break off
Step 4: Sanding
Picture of Sanding
After you remove the tabs remove the cover and sand until all the paint comes off and looks like this
Step 5: Cutting (Yay!)
Picture of Cutting (Yay!)
on the side thats opposite the tabs your broke off cut two more for ventilation and on the shorter two sides cut one on each side and looks like the next pics
Step 6: Finished (finally)
Picture of Finished (finally)
what you do next is clean the altoids lid really well thats the pan
then just pour in your flammable liquid and light in as seen in the next pics
and put the lid so that its perpendicular to the rest and there you go
(Please Leave Comments)
Lighting tip: get a popsicle stick and dip in the fuel and ten light and tap into stove real quick for a quik light
chapstickman (author)2015-06-01
ingenious. you can store the feild in a container in the tin then take it all apart and make a stove when you get to your campsite
iApple guy (author)2012-03-27
That fire is too high!
weaponscollector94 (author)2009-08-23
what the heck are bootleg Altoids?
cheap immitation altoids, he sould not have called them bootleg, because bootleg referrs to something totally diffeent. :)
bylerfamily (author)2009-04-14
Cool! Oh,noticed a mistake.You said,I use 91 percent denatured alcohol.The photo of the alcohol bottle clearly says"Isopropyl rubbing alcohol".Just thought you might want to correct that.
daelans (author)bylerfamily2009-05-03
how canyou read that and where?
bylerfamily (author)daelans2009-05-04
On the materials list he says,I use 91 percent denatured alcohol. In the picture of the alcohol bottle the bottle say isopropyl alcohol
IdahoDavid (author)2007-03-19
This is very similar to some of the alcohol stoves we use for backpacking. A couple of suggestions: If you line your tin with some fibreglass insulation -- just enough to fill it without packing it in -- and then cover that with some metal window screen cut slightly larger than the bottom tin you can insert the screen under the rolled edge of the tin. What this does is give you a nonflamable material to pour your fuel into. This reduces the danger of the fuel splashing out or spilling. The screen holds the insulation in place and also helps to spread out your flame and gives you a more controlled burn. I would also recommend using denatured alcohol -- you'll find it in the paint section of the hardware store. Rubbing alcohol has water in it that will make it burn with black smoke. Denatured alcohol is purer and burns cleaner. You can also use the product HEET, but get the kind in the yellow bottle.
cd41 (author)IdahoDavid2008-11-01
I was thinking something like lineing it sortof like you sai, but line it with something that wont burn(what you probably doesn't burn cause your suggesting it) that and yeah put something to keep the fuel from flying out then some crazy people might be able to hold an altoids tin fire tin
lightpacker (author)IdahoDavid2007-03-20
thanks for the tip but i jus used this stuff cause I dont own any means of transportation that will get me very far (I'm thirteen [ Look at the Finding Nemo Bedspread ] it took me like 3 hours just to make this instructable) Thanks for the tips though I'll try to get my dad to buy me that stuff
Sunbanks (author)lightpacker2007-11-22
:D I love Finding Nemo!
IdahoDavid (author)lightpacker2007-03-21
Understood. Next time you might want to fuel and light the stove somewher other than on your bed.
lightpacker (author)IdahoDavid2007-03-21
I know but i was in a hurry I'm at an age that i still have a bedtime No later than eleven
pekrwood88 (author)2008-02-26
http//en.wikipedia.org/wiki/Beverage-can_stove check this out has a nice concept
Stev0lution (author)2007-03-18
What do YOU use this for?
lightpacker (author)Stev0lution2007-03-20
nothing some minor cooking once in a while but i just wanted to show proof of concept. And a revision of my earlier advice i dont recommend cooking on the lid just put some foil on it or metal foil its really hard to clean the lid
bruc33ef (author)lightpacker2008-02-10
That's what you say to your girlfriend when you get older -- Babe, I just want to try this for 'proof of concept'.
supergluerules (author)2007-06-28
neat idea I will modify it slighty but overall very cool
nicevidoe (author)2007-06-14
best instructable yet. post some more sometime. YOU OWN!
lightpacker (author)2007-05-29
never because nothing is compressed it might make a big fire if you spill the fuel but never explode
Yerboogieman (author)2007-05-27
will it ever blow up?
chickenliver123 (author)2007-05-19
you can cook clams on the pan. make sure it dosnt touch the fuel...
chickenliver123 (author)2007-05-17
AWESOMe, but its going to take like 30 min. to boil water, maybe you should crush some charcoal for the fuel. Swizzle i right tooo, it might start a fire because it is wobbly.
swizzle (author)2007-03-21
Why not put some type of notches in the lid to stablize it. Otherwise it could be pretty wobbly and possibly tip, causing a fire. Swizzle
lightpacker (author)swizzle2007-03-22
Good Idea Works even better
Wonderground (author)2007-03-19
How to take off a lid.
lightpacker (author)Wonderground2007-03-20
break off hinge where lid is held on jus keep on bending till it breaks off or you can just cut them off with the rotary tool Sorry for the delay of comments
rasengan609 (author)2007-03-18
cool it works great
About This Instructable
6,551views
15favorites
License:
More by lightpacker:Make Your Own Cushtop ($2.00 instead of $40.00)Secret Safe ThingyEmergency International Plug to US Plug (Electrical Outlets)
Add instructable to:
