3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MintyBlaster - Altoids Stereo Speakers
Introducing the MintyBlaster - a tiny amplified stereo speaker system! Rock the block with 0.5 watts of power per channel!
This is mostly a re-purposing hack - modifying a finished product into something else. Some basic tools and soldering are all it takes.
I built this a about a year ago but all parts used are still available. Where I won't be able to show you actual construction I will go over how to accomplish each step.
Step 1Parts
Parts
Parts required:
- an Altoids tin, of course. Full-sized.
- a "folding ipod speaker" like the one in the photo below. $0 - $15, depending on if and where you buy it.
These are available all over - buy the cheapest one or you may find one at a thrift store or even already own one. We use it for the amplifier board; the speakers are too big. Mine had a tea2025b amplifier chip - it's like a dual lm386 but rated for 2 x 1 watts into 4 ohms at 6v input. It doesn't matter so long as the board isn't much larger than mine (it's a tight fit in there).
I think you will be hard-pressed to breadboard something like this yourself and make is as small. If you can etch your own boards, then you could use one of the tiny surface-mount chips which do not need DC-blocking caps on the outputs. The DC-blocking caps take up the most room.
- a pair of miniature speakers, Electronic Goldmine G18251 (www.goldmine-elec.com). $1.00/ea at time of writing.
Mine were removed from an old Sun Microsystems thin client, but these are the exact same thing.
- A stereo mini-jack cord. $0
If you've owned a couple of mp3 players you probably have one you don't need. You could also use one from headphones, but the wires might be very thin gauge and hard to use.
- a 4 AA battery holder with switch, Jameco 216187 (www.jameco.com) $1.05 at time of writing.
The one thing I disliked about the folding speakers in their original form was the use of AAA batteries. They just don't last very long. Since we have no room left over in the Altoids tin for much of anything, I went with an external pack and glued it onto the back. Yeah it sorta violates the spirit of an Altoids hack, but it more than doubles the run time and it helps the whole thing stand upright without falling over. You can get this without the switch, but it's useful, as it is hard to mount the board in the tin so you can get to its power switch easily.
7 comments
Dec 28, 2011. 2:33 PMmacwhiz says:
I think im up for that challenge! If I have time to do it i'll let you know, but i think an external charging dock would be a good idea
Nov 11, 2011. 8:42 AMairgunguy123 says:
where do you get chocolate altoids
Oct 12, 2011. 6:59 AMbatman96 says:
I built something like this a couple of months ago, but I used the amp board out of some old small computer speakers, the case was foam board and the speakers where two JVC car stereo tweeters, they sound pretty good and have a full range when they are under powered like they are, It uses 3 AA Batteries or a 5v power adapter, being that they are car speakers and the board used to power moderately big speakers it is LOUD. For how small it is it is REALLY LOUD.
Batman96
Oct 10, 2011. 5:06 PMTSC says:
Cool!
Oct 9, 2011. 1:00 PMThe_Warlock says:
i think I'm in love
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:uhclem
You know, I think we're all Bozos on this bus
