3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MintyBoost! - Small battery-powered USB charger
Step 19Make: Done!
Make: Done!
OK, insert the MAX756 boost chip so that the little notch in the chip matches the notch in the socket. Make sure its well seated: press firmly, making sure all the pins are sliding into the socket straight. You're done!
« Previous Step   View All StepsNext Step »
2 comments
Apr 29, 2011. 10:04 AMandrewschexneider says:
where can you find just a plan usb port like that?
May 31, 2006. 10:26 AMckthorp says:
Probably should note for people without much kit building experience: you will have to bend the DIP leads a little bit to get them into the socket. This is normal. They are bent a bit from the factory to make it easier for mass assembly robots -- the leads spring back after the robot places the chips into the PCB so the chips don't fall out between placing the parts and wave soldering.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
278
Author:ladyada
i r0x th' x0x & s0x [http://www.ladyada.net more stuff here]
