3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MintyBoost! - Small battery-powered USB charger
Step 4The Process: Enclosure selection
  • last photo ←
So at this point I start thinking about enclosure and size. Most people think of this last, and that's a bad idea. If there's one thing I've learned from hacking on electronics, its that you should try and select the case first because it dictates a lot of the electronics and interface.
I know that the parts for the kit must be all through-hole (no surface mount) and easy to work with. I also want AA batteries, 2 is good although I know from experience that most boost converters will work with any number from 1 and 3 just fine. I have a predilection for Altoids tins and I also know that I can fit ~2 AA's into a gum tin so I pull out a tin and take some measurements.
OK 2 AA's fit well, so now I rummage through my collection of battery holders and find one (PCB-mount) which seems to be pretty good, it doesn't have a switch but I don't need one anyway (see quiescient calculations, later on)
So I take some measurements...Looks like I have about 1.25" x 0.7" semicircular PCB space at the top for the circuit board.
I also try out another battery holder I have, this gives me more space, 1.25"x0.85"...but the batteries go in sideways so one would have to remove the holder to change the batteries. I'd prefer that you can just take them out directly, so I don't go with this one (it also turns out I don't need that extra space)
(I now do a little hack to turn the PCB mount 2xAA battery holder into a wire-lead one. Basically I just solder on red and black 6" wires and clip off the PCB through-hole leads. This is actually a little difficult because the plastic melts and you have to sort of keep it in place while you solder. Its not suggested :) )
Now that's done I'm ready to think about what I can cram into that space.
« Previous Step   View All StepsNext Step »
5 comments
Jun 22, 2008. 9:48 PMculturalsalad says:
is it possible to add a handful of batteries to this setup... lets say around 14 or maybe 28?
Dec 9, 2009. 7:19 PMmiked789 says:
If you use enough batteries, then you wont need some of the parts. Say you use 6 rechargeable, you get 6 * 1.2 volts = 7.2 volts total (in series).
This is enough volts that you don't need the IC that increases the voltage of two batteries. So all you need is the 7805 regulator and supporting parts.
And because of the large number of batteries, it would allow the ipod to work much, much longer. Probably three times longer as the two battery version. It might be worth it if you are camping, or off somewhere where you wont have access to AC power.
Downside is, you have a battery pack that is three times the size.
Feb 20, 2010. 6:31 AMjono456 says:
 You are making it way too hard. If you have no problem with the number of cells use 4 NiMH or NiCd cells in series and completely forget about any other electronics. The voltage will fall with in the USB spec. and it works and works with no losses as is introduced with any of the boost or other regulator circuits.
To put it another way, 4 NiMH cells in series doth a USB charger make. That's it.
If you want smaller size but no introduced energy losses due to the electronics connect 4 N cells in series. That will make a package about the size of 2 AA cells.
Sep 28, 2009. 4:36 PMnotoriouss says:
Lol, that would take out the "inside in altoids can" idea.
May 31, 2006. 10:01 AMckthorp says:
A workable digital caliper doesn't have to be expensive. See here: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47257 No affiliation, just a happy customer, yadda, yadda, yadda.
Jun 9, 2009. 12:12 AMsirchadlee says:
thnx for the link i might get that. i tend to just kinda round numbers and end up just crammin stuff into to small spots. to the lady, that caliper is sexy. also im thinkin that you could prolly cram another pair of batteries on the top, right? or would it just become a cluster of wires that is too hard too work with?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
278
Author:ladyada
i r0x th' x0x & s0x [http://www.ladyada.net more stuff here]
