MintyBoost! Kit V1.1 and 1.2
This is an updated version of the detailed instructable by this device's inventor, Ladyada. The updated version has some extra components. Questions about this device should be directed to Ladyada's forums, and the project site has a similar how-to.
This instructable now covers version 1.2 of the kit as well. Version 1.1 and older have green PCBs, and the version 1.2 is all white. The only major difference in 1.2 is the R5 resistor placement. Step four on resistors has more information about it. Other than that, you can follow the further directions without worry.
Also, if you do have a v1.1, there's a slight modification to make it work with new iPods. In version 1.2, the modification is simplified.
You can buy the v1.2 kit at the MAKE store.
This kit is great for soldering beginners. To learn the basics of soldering check out this great guide by noahw. Also, here's a good video tutorial from the MAKE blog.
Step 1What you get and what you need.
The list here is for parts from the V1.1 kit. The only real difference is the two resistors.
What you get with the kit:
1 x IC1 MAX746 with Socket
2 x C2, C3 Power Supply Capacitor
2 x C1, C4 Bypass Capacitor
2 x R4, R5 10k .25W Resistor
1 x D1 Schottky Diode
1 x L1 Power Inductor
1 x X1 USB Female Jack
1 x Battery Holder
1 x PCB
What components you'll need:
2 AA batteries
What tools you'll need.
Rosin core, 60/40 solder
Soldering Iron hopefully with a pencil-like tip
Wire clippers
A vice to hold up the PCB
(You can get all this stuff really cheap at http://www.all-spec.com/ or http://www.allelectronics.com/)
38 comments
Jan 31, 2012. 5:06 PMgerik9 says:
does anyone know if it works with a zune?
Jan 4, 2012. 5:38 PMdragonriot says:
LadyAda, I have already built one MintyBoost, and it's awesome. I have a second kit waiting to be assembled (I'm actually giving it to my son as a late Christmas gift) and I'm wondering if you or anyone has ever included a USB charging port to actually charge the MintyBoost itself without taking the rechargeable batteries out and having a separate charger? I have the plans for a nice and slim USB charger for 2 AA batteries that would definitely fit in a large altoids tin, which is what I'm using anyway. Do you see any issues with having the charge port on one end, and the discharge port on the other end?
Jun 22, 2009. 7:43 AMemmjul says:
Did anyone try charging a Creative Zen Vision W, because it doesn't work with the pullup configuration, wich works with the Ipod Touch, and I don't get it, how to install R5 as pulldown, did anyone try it before???
Jul 16, 2008. 11:51 PMDerin says:
can you post the schematic,I want to make one but not in a altoids tin and not on a premade kit,I can't get hold of those because I am not in the US.Help appreciated.
Jan 25, 2009. 9:02 AM-henry- says:
The schematic and PCB files are here
Jul 16, 2008. 11:39 PMAngus06 says:
Hi, I asked the same thing on another instructble, but... How do you know how many capacitors and of what capacitance to use when designing a charger like this?
Jun 14, 2007. 1:39 AMsk8erman541 says:
umm.. yeah i ordered this kit in the mail and it got here fast. i liked the kit it was fun and easy to make. this was my first time sodering and i did suprislingly good here r some pics..
Apr 11, 2008. 7:51 PMstruckbyanarrow says:
where are da pics?
May 3, 2008. 5:51 PMsk8erman541 says:
idk i thought it said it put them up and i dnt have them on my computer ne more
Nov 27, 2007. 3:08 AMkurt1978 says:
Hi, I have done something simulare like you for my GPS. However when I use it, it will charge but also the screen will go into a mode that thinks it is connected with a PC. So i can't see my cart anymore (so i can't use my gps while charging). Is it possible to prevent this so i can use my gps during charging? Thanks Kurt
Nov 25, 2007. 12:51 AMbuddyboy says:
how would I go about decreasing the current from 1A to somewhere around 350mA while leaving the voltage at 5V?...cause my phone uses i think 350mA instead of 1A
Nov 25, 2007. 8:25 PMbuddyboy says:
If i use V=IR i need a 14 Ohm resistor is needed....is that right? and if so where would it go?
thanks
Apr 9, 2007. 10:03 PMfnords says:
im gong to do some modding on my minty, but im completely new when it comes to building anything electronic, so heres the poser: if the output of the mintyboost is 5v @ 100ma and the batteries together usually drain at what..3v @ 300ma (i hope thats right), are the batteries in the mintyboost circuit draining at 100ma or 300?? sorry for the stupid question, but im new
Apr 9, 2007. 11:06 PMfnords says:
muchas gracias intersting for you of all people to respond. im building the boost mostly off the data on your 'mintyboosty meta documentation' page :P
Apr 9, 2007. 10:26 PMladyada says:
if you are drawing 100mA from the mintyboost at 5V then the batteries are draining at 5V/3V * 100mA * 120% = 200mA or so. The 120% is to cover 'inefficiencies' in the conversion process.
Apr 16, 2007. 12:26 PMfnords says:
one more question ladyada, if i hook up a solar cell to the batteries which gets 3v @ 22 ma, about how long will it take to recharge the batteries?
Jul 16, 2008. 11:52 PMDerin says:
depends on the capacity of the battery,mine are 2700mah for example.
Apr 3, 2007. 9:49 PMpoolshark1691 says:
Ive checked this out before, and came very close to ordering the PCB board from adafruit, however i do not like web transactions (yes, even good ol' paypel), is the same PCB board used here available retail?? Because i know in the original article, you mentioned that the PCB board was "etched" and basically messed around with. So again, is there a way I can get that board in stores? I would very much like to do this project.
Apr 9, 2007. 10:25 PMladyada says:
adafruit takes checks/money orders all the time for those who dont like putting their info online. also, EYEBEAM in NY stocks some of the kits and you can just walk in. Not available in Walmart or Target....yet :)
Mar 27, 2007. 4:38 PMdcshoeco33 says:
this is a copyy of ladyada's
Apr 2, 2007. 8:51 PMAmadeos says:
lol, its a simplified version, I think... I love ur Avie, Eddie OWNS!
Apr 1, 2007. 7:39 PMsuper_genius says:
HAHHAHA LOL IM SORRY MAN!!! I did'nt READ the list. im really sorry, but still you might want to consider putting the rating in the pic for us dumber (sarcasm) people so we wont get confused.
Apr 1, 2007. 7:37 PMsuper_genius says:
ok um dude, first off you need to let us know what the ratings are on... everything. like, u say two blue supply capacitors, what uf?!?! and what ohm rating are the resistors? The thing that bugs me the most is what is the ic pin rating? is it a 555 or a 479? there are more but ya gotta get ur stuff right man!! the resistor can be substituted by a couple of different resistors, but the ic pin cant. cuz I really wanna make this but I cant cuz I dont know the stuff
Mar 31, 2007. 2:44 PMjbond says:
I keep looking at this as a basis for running a 2.5" disk drive from a 1.8" connector. Specifically hacking an Ipod to run a phat 2.5" disk. 1.8" disks run off 3.3v while 2.5" are 5v. The problem is the current supply. Do you think the Mintyboost circuit would handle that?
Mar 27, 2007. 4:44 PMlemonie says:
The USB plug looks a bit short, is this long enough to connect? I guess Altoids must be like Marmite: pretty much unheard of on the other side of the Atlantic? (I have heard of Altoids though)
Mar 28, 2007. 7:54 AMladyada says:
The company that makes Altoids is British! http://en.wikipedia.org/wiki/Altoids
Mar 31, 2007. 9:21 AMimajoebob says:
Callard & Bowser was a British company. It's now a subsidiary of Kraft Foods. They're reported to be moving production from the UK to the US. I've been mad at them since they cancelled production of their hard butterscotch, perhaps the best candy ever made. But they still make a fine battery case.
Mar 28, 2007. 10:51 AM!Andrew_Modder! says:
yeah.. they sure are lol
Mar 27, 2007. 7:18 PMevy-wevy says:
for some reason, mine didn't need the extra resistors...was this becuase i have an original 5 gen video ipos, or is it becuase im special...
Mar 28, 2007. 7:52 AMladyada says:
the resistors are there because many devices do need them like the new nano and shuffle ipods- better safe than sorry! :)
Mar 27, 2007. 6:36 PMLasVegas says:
To stabilize the USB-B connector, I would recommend that the "clips" be soldered into place as well. I've too often seen connectors, without the shield soldered down, work their way loose and cause bad connections. As a side-note: Back when I worked for Control Data Corp, whenever newly constructed circuit failed to work and the technician couldn't find the problem, we would jokingly recommend that he try replacing R5! I just struck me as humorous as R5 was the solution for your low current problem.
Mar 27, 2007. 6:32 PMmrmath says:
I looked on both sites you pointed to, and couldn't find the USB plug. Can you provide a direct link to it? I was looking for a pair of USB, one male, one female, for a very easy project, but couldn't find them anywhere. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:MAKEkits
