3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MintyBoost! Kit V1.1 and 1.2
Step 4Resistors & A Special Note.
Version 1.2 (white PCB) makes configuring the Minty Boost for newer devices easier, since the R5 resistor has two placement options. (See the photos)
The designer suggests putting the resistor in the "pullup" position (last photo) for best compatibility. However, if that doesn't work you can always clip the wire and try the "pulldown" position.
Bend the resistors as shown in the first image, and stick them into their tight spots, R4, R5. Follow the soldering procedure used in the other steps. Remember, follow the R5 pullup position first especially if you have a newer iPod (this was written in Spring 2007).
NOTE for V1.1: If you have a new MP3 player like the iPod nano 2G (small metallic), Shuffle 2G (metal clip), Zune player, or if you are not getting your device to charge when you're finished constructing this, you'll need to modify the component lay out a bit.
It's pretty simple actually. One leg of the R5 resistor can be soldered to the + power contact. See the last images for details.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:MAKEkits
