3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MintyBoost! - Small battery-powered USB charger
This project details a small & simple, but very powerful USB charger for your mp3 player, camera, cell phone, and any other gadget you can plug into a USB port to charge!
The charger circuitry and 2 AA batteries fit into an Altoids gum tin, and will run your iPod for hours: 2.5x more than you'd get from a 9V USB charger! You can use rechargable batteries too.
Some numbers...
iPod video (tested, using alkaline batteries): 3hrs more video (1 full recharge)
iPod mini (tested w/rechargeables): 25 hours more (1.5 full recharges)
iPod shuffle (unverified): 60 hours more (5 full recharges)
Weight (with 2xAA): 3.5oz
This project is suitable for beginners, some soldering tools are necessary but even if you've never soldered before it should be pretty easy. You can etch a circuitboard and/or breadboard this up, or simply buy the kit from the adafruit webshop.
I've also documented the process of designing this kit, in case other people interested in designing and making kits are interested in learning how to start selling their own kits!
This project was developed under support from EYEBEAM, thanks!
  • NOTICE!!!
  • This instructions are outdated, some
  • minor changes have been made to
  • the kit to make it better. If you're building
  • a purchased kit please read the docs at:
  • http://www.adafruit.com/make/mintyboost
  • THANKS!!!! - ladyada
Step 1The Process (Meta documentation)
This next 10 steps detail how I went through the process of coming up with the idea, hardware, design, etc. for this project. It's not 100% correct but it's pretty close. Since this project only took 2 days (on & off) to design/test/release, it's a lot easier to keep track of than something enormous like the x0xb0x.
I also include the schematic/layout files in Eagle format. The prototype one is best for etching at home (its single sided)
« Previous Step   View All StepsNext Step »
547 comments
1-40 of 547next »
May 25, 2012. 3:16 AMVedant Raval says:
Hey Can dis circuit be used for a 4-volt input battery(18650 kind li-ion cell,,2400mAh)????
coz i got six of dem from a laptop battrey.....
It would be great if you would help.......thanks
May 1, 2012. 3:09 PMaerinthaare says:
How much would it cost me to get one of these pre-assembled? I would love to get my hands on one of these, but I solder like an epileptic squirrel at a rave party. I have looked around the internet for a usb charger to run my headphones with, but they never show me the actual power specs for the device output; I do not trust said products.
Mar 25, 2012. 8:45 AMZach4997 says:
https://www.adafruit.com/products/14
This is where to buy this. I posted this because it said the link was down so, Yeah.
Mar 8, 2012. 9:52 AMnodoubtman says:
Mouser is 20$ shipping .. too much!
Jan 25, 2012. 4:43 PMnkiegrea says:
This is probably one of the coolest things I have ever seen. I downloaded the layout files and I am looking at various PCB Manufacturers... Custom Circuit Boards looks pretty good for these type of prototypes.
Any other suggestions for prototype projects like these?
Dec 22, 2011. 2:08 PMthanatos370 says:
If I wanted 2 parallel banks of 2 AA's to increase charger time, would your circuit work still?
Oct 30, 2011. 3:40 AMmutantninja6458 says:
I am from the uk and i am looking to build this kit. i was just wondering whether this is the right boost controller:
http://search.digikey.com/uk/en/products/MAX756CPA%2B/MAX756CPA%2B-ND/1130177
Dec 18, 2011. 4:00 PMdragonriot says:
Looks about right... I haven't actually looked at the parts list, but all the voltages and stuff on your link are correct
Dec 13, 2011. 12:49 PMflocha says:
Hi, great project. Does anyone by any chance know the name of this components in Spanish?
Thanks a lot.
Dec 10, 2011. 8:45 PMwhatchitfoool says:
what is he using to hold the pcb? id love to know what type of vice that is
Dec 4, 2011. 8:49 AMknexfreak32 says:
i see how this works it uses 2 1.5 volt batteries and then a voltage doubler finely a resistor to bring the voltage from 6.00 v. to 5.00 v. very simple.
Nov 8, 2011. 5:24 PMjlund says:
what r the parts caled i would like to know riten now so i can go buy them befor radioshack closes
Nov 8, 2011. 3:02 PM09khanyu says:
Forget about that. I hadn't checked the user manuel on the original website
Nov 8, 2011. 2:56 PM09khanyu says:
I would like use this to power an arduino with a 3.7V Li-Ion cell. Would I need to make any changes to the components.
Nov 28, 2010. 4:51 AMlegless says:
You say a 9V battery has a high internal resistance and then quote ~2ohms. That is incredibly low resistance - it's almost a dead short. Did you mean it is more like ~2Mohms or something?
Oct 27, 2011. 4:43 PMchadbobb says:
batteries are close to an ideal voltage source. An ideal voltage source has a resistance of 0 ohms. 2 ohms is actually pretty high for a battery. Most AA batteries are like 1/4 to 1/2 of an ohm. Shorting it would produce about 3.4 amps
Oct 19, 2011. 2:42 AMggardner7 says:
cool
Sep 12, 2010. 4:07 AMchndt2008 says:
Great! China already has the product, price $ 2, I believe they stole your technique. I am Chinese, but I hate the Chinese. . . But such products have a question, that is unstable and may damage the battery. Reduce the battery life, which is found after a lot of people use.
Aug 11, 2011. 9:06 PMnpandey2 says:
friend can you send me the schematic diagram of your chinese version at nitesh.pandey@ymail.com,i want do do practicle and make it myself,help is appriciated
Sep 12, 2010. 5:21 AMmistercrazy says:
I can't find that MAX756 controller in my region(I'm in japan!)
of course i looked through "digi - key" but they didn't have it in stock.
is there any alternative? Please help ;E;
Aug 11, 2011. 9:04 PMnpandey2 says:
hello friend,did you got any alternative solution to thi ic,me to facing same problem,m from india?your help is appriciated
Aug 9, 2011. 11:12 AMludionis says:
I just made a similar item, but I used a 4-AA battery pack with on/off switch from radio shack :)
Aug 11, 2011. 8:44 AMnpandey2 says:
friend can you plz mail the schematic diagram of your circuit,i am intrested in do it yourself..id is nitesh.pandey@ymail.com
Aug 11, 2011. 7:55 PMludionis says:
I simply bought a 4-AA battery pack holder, tool an old female usb port and wired the + and - to pins 1 and 4 of the usb port, taped it all up to protect it. Not really a circuit to map, sorry.
Aug 11, 2011. 9:01 PMnpandey2 says:
thankx,did that worked??it delivers huge current??any heating problem??
Aug 3, 2011. 5:20 AMrnicholls1 says:
does the Minty Boost have to be battery powered or could you possibly draw power from another power source such as a solar cell or Lithium polymer battery?
Mar 20, 2011. 4:52 PMkoolariz says:
too expensive :(
9$ boost converter
10$ shipment cost
4$ misc.
already too much, when a 7805 is 1/2$
and if i invest in new rechargable batteries i might as well buy a second battery to carry around. or even a phone..
the project sounds tempting, i'll sleep on it.
nice job, btw.
Aug 2, 2011. 11:44 PMtechxpert says:
futurlec to the recue
May 13, 2011. 6:02 AMluftwaffe29 says:
guys im sorry to barge in like this but i desperately need help in making a cardboard biplane. ive gotta couple o questions. will anyone please be kind enough to answer them
Aug 2, 2011. 11:43 PMtechxpert says:
say yes or ok if you still need it
Jun 11, 2011. 9:18 AM239hobbies says:
Hey, will this charge an HTC Evo? It does charge on usb, however I'm worried it will pull out to many Mah to fast. I have tried just using a 7805 regulator and have had no luck. I just dont want this thing overheating and destroying a $500 phone.
Aug 2, 2011. 11:42 PMtechxpert says:
don't worry it wont do anything to it it cant fry with this cicuit
Jul 8, 2011. 1:19 PMckrill1 says:
does this work with the ipod touch forth generation?
Jun 19, 2011. 7:35 AMTIDGE27 says:
Great instructable!
Please may you send me the eage files
May 12, 2011. 1:54 AMjwoo2023 says:
ack! digikey is out of the inductor!
Apr 29, 2011. 10:04 AMandrewschexneider says:
where can you find just a plan usb port like that?
Feb 27, 2011. 10:11 AMKanellos says:
Is it compatible with the Zune HD?
Mar 13, 2011. 7:10 PMroland985 says:
It provides the 5v USB power. If the zune can be charged by USB: Yes...
Mar 2, 2011. 1:07 PMipod touch 4g says:
How easy is this to build? And what keeps you ipod from overcharging?
Mar 13, 2011. 7:09 PMroland985 says:
Most probably, the iPod's internal regulator
1-40 of 547next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
278
Author:ladyada
i r0x th' x0x & s0x [http://www.ladyada.net more stuff here]
