Want to help your vain friend stay in touch? Send a mirror postcard to him. The next time he decides to gaze upon his own heart-stopping beauty to make sure no slight imperfection has slipped in he will both remember where he lives for a safe journey home as well as your own address in case he should ever decide to forsake the transient electronic messages for a more solid form of communication.
Step 1Etch and Cut
Etch the mirrored acrylic and cut it with a laser cutter. Once again, I'm using the Epilog at Squid Labs to get this stuff done. Here you can see the laser cutter doing the vector cutting of the postcard shape.
It should go without saying, but the etching always happens first. Otherwise, the surface will drop down a bit and even get sightly turned to one side. For designs that go to the edge it's a good idea to have a slight bleed to the design as well.
http://www.dailymotion.com/swf/1Ig0imgc956yg3Akj
You left out step 1: Purchase or Obtain Access to a $15000 Laser Etcher.
Also, is there really much instructional content here? Would you post an instructable on how to print a postcard with an inkjet printer and mail it?
Seriously, I totally hear you on the laser etcher part. I even complained on an instructable ages ago about the same thing before I had access to it. But the thing is, this can be done with less than $50 worth of tools as well. It's just that the laser etcher makes it a lot faster and cleaner. The same is true for ALL of the projects I've put up here with a laser cutter.
I usually try and put some alternate instructions for the low-tech method. On this one I didn't and I apologize. I'll update it later.
What I'm trying to do is to try out different mediums to send through the mail. Is the medium the message? Maybe. I'm just curious what different shapes and appearances and reuses can be interesting to look at and the fact that it gets accepted and processed by a separate system I have no control over makes it more fascinating.
So how to do it? Score the edges with a knife, then break it apart with some pliers (bonus points for putting slats on to spread out the pressure). Now dremel the edges to clean it up and round the corners. Then just grab a sharpie and mark up the addresses. There ya go.
