3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Miso-rubbed Roast Turkey
Step 2Rub down turkey
Rub down turkey
Place your (fully thawed) turkey in its roasting pan, breast-side up. Make sure the bowl of miso rub is easily accessible.
Starting at the back of the bird (larger cavity) run your hands under the skin of the breast, and spread your fingers to detatch the skin from the meat. Wiggle your hand around to the leg/thigh area, detatching as you go. Spin the pan and do the same thing from the front of the bird. If this doesn't look positively indecent, you're not doing it right.
Scoop up some miso rub, and shove it in under the skin. It's fine to leave big miso lumps; you can massage the skin from the outside to spread it properly. Work about 75% of the rub in under the skin, trying to reach as much of the bird surface as possible. Flip the bird over, and rub a bit more into the surface of the skin on its back, then return to original belly-up position. Rub remaining miso onto the outside of the breast and leg skin.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
414
Author:canida
I've been posting Instructables since the site's inception, and now run Community and Marketing. Follow me for food and more!
