loading
loading
Picture of Miss Betsy's Coffee Table Lamp
Before I even knew instructables I built this lamp to mount over the coffee table in my basement. I think copper must have been a lot cheaper back then. ;p
As this light fixture was glued and soldered together I didn't want to take it apart to make this instructable, but assembly is quite easy and straightforward and you shouldn't have any problems to put this or something similar together after reading my instructable.
Be aware that you are dealing with 120V which can be deadly! Don't attempt this or get professional help if you are not sure how to do this!
Material:
2' 3/4" copper pipe
8' 1/2" copper pipe
12 1/2" T's
8 1/2" L's (sweat)
4 3/4" to 1/2" reducers
4 1/2" to 3/8" reducers
2 Bakelite lamp sockets
4 2" 1/8" threaded pipe (3/8" O.D.)
8 1/8" brass lock-nuts
2 1" loops (threaded with wire way)
2 #4 brass screws
2 13W Mini fluorescent lamps
2 lamp shades to your taste
#18/2 lamp cord (several feet)
Tools:
Blow torch and solder
Glue suitable for metal
pipe cutter
drill and drill bits
#4 tap
Screwdrivers and wrenches
Step 1: Gathering your materials
Picture of Gathering your materials
I made a sketch first and then figured out how many fittings I would need. Then I laid it out on the floor to check if I had everything.
It has its advantages to polish the copper parts before the assembly! I also threaded the wire right through the separate pieces because after assembly it might be quite difficult.
Step 2: Assembly
Picture of Assembly
As you can see, assembly is quite straightforward. Just take a copper fitting, apply glue according to the instructions and press together.
onrust2 years ago
You got the touch......that's just smooth.
This is a brilliant idea to hide the energy saving bulbs on a very, very pretty way! :-)
It looks like one of these wonderful gas light chandeliers.
With kind regards,
Horatius Steam
MissBetsy (author)  Horatius.Steam2 years ago
Gentlemen, you make me blush :)
Thank you for your kind comments and I have to admit that I always get some inspiration from your creations.
Keep up the good work MrMr. Junophor and Steam
Junophor2 years ago
Hi Miss Betsy
I am deeply impressed of your objects
As Horatius Steam already wrote; It reminds me to old gas lights too! Very cool I have to hurry and take to look in my copper tube storage.......
Keep up your work!!
Aeon Junophor
tinker2342 years ago
wow i think edsion style bulbs would look amzing in that heres a link http://www.amazon.com/Bulbrite-134020-Nostalgic-Edison-Loop-style/dp/B0030B3ROW/ref=sr_1_2?ie=UTF8&qid=1333823461&sr=8-2
MissBetsy (author)  tinker2342 years ago
These lamps sure look good but nobody can really appreciate them with the shades on so these energy saver ones do the job.
