and of course each single one inspired me, if only maybe, with a little detail.
So what is new then you might ask. Probably some choices of materials for some of the parts,
the one or other manufacturing step and the installation of an USB illumination. Maybe you
want to look just at more pictures and find a little detail that you didn't see mentioned
anywhere else and inspires you...
I spent quite some time pondering about the choice of new keys. Old typewriter keys, offered
on eBay are quite expensive and usually only about 40 pieces per set. I would need at least 2
if not more of these. I also couldn't be sure if they were looking the same or at least similar. I went to Jo-Ann's to look at buttons but these were prohibitive expensive; about 3 - 6 dollars for a set of 5 or 6, depending on the make. I was really disappointed and was ready to leave the store when I saw in the last row at the very bottom these grab bags with about 100 buttons in 5 different sizes for $2.60. 5 of these would yield enough large buttons for all the keys I needed but could someone point me to an Instructable to use up 500 of the smaller ones???
Anyway, I was relieved and bought also 1' strip of velvet there.
Do not attempt this if you are not equipped with lots of patience; some of these steps need to be repeated 100 times which can become quite boring and is tedious!
Approximate costs, depending on your choice of materials and level of detail, ~ $ 40-80.
I am really lucky as the previous owner of my house in his late 80ies was a printer and left me a basement full of "stuff" and also some tools. Wherever he is now, I am very thankful!
Please vote by clicking the stars on the right side!
Please check my Steampunk Mouse too. NEW NEW NEW Steampunk Monitor
Tools used:
Drill press
Emerald paper
Assorted screwdrivers
Scissors
X-ACTO
Files
Soldering iron
Propane torch
Different Glues
Pipe cutter
Hack/metal saw
Table saw (or a friend with one)
Materials:
1 keyboard
Buttons (about 100-110)
Some nice piece of fabric or leather/vinyl
Spray paint
1/2" Copper pipe and fittings
Bic pens or similar
Styrene sheet (1/16", maybe thicker) and profiles
2 LED's + matching resistors (LED calculator)
on/off switch
#6 and 8 brass screws
Helpful:
A good friend who is willing to help and has all the tools you don't have.
Gallons of coffee, tea or your preferred stimulant.
A glass of wine or beer or your preferred relaxant to think things over....
(Pictures were not always taken in the order as they are arranged in the steps)
Remove these ads by
Signing UpStep 1Get a keyboard
Maybe you take a picture of the keyboard to make sure you know where the particular keys go. (Or just keep the carton it came in for a change ^_- )
On closer inspection I found that all my keys were the same; that is not necessarily true with all keyboards and might make slight changes in making the new keys necessary.
When will someone steampunk a PC? That would be nice to go with that beautiful keyboard.
I am enjoying this instructive very much and may see what I can find at the Goodwill for parts...
To JasonMyers:
Try AVG Free Edition, it's got so many more accurate signatures than the "pay for your continued fear" commerical programs. Last time I got the GIMP it was fine and I checked it with a few different anti-vir programs.
Sincerely,
DIY-Guy
That would keep the wires out of sight and less 'vulnerable'.
It would also make it possible to place the on/off switch of the leds in the keyboard case.
btw, you really should have used a metal toggle switch. One that has this red and silver plate with the on/off text. Much sexier than a slider... ;)
Nice keyboard anyway.
The black ones with no teeth,
I am pretty sure they make the same type for metal .
If I put a small copper gear somewhere, it should imply that it serves a function, meaning there should be more to it. As an inspiration take a look at pictures of victorian steam somethings to see what I mean.
What about this? This would fit i well and look good as a medium sized cog/gear and would fit the theme. What do you think? Too many wires? Or could you use a bigger shoelace like the mouse mod you did and fit all the wires in that?
If you look at this steampunk USB drive, there is a window with gearwheels underneath which do absolutely nothing but imply that there is a working mechanism in it, that's what could be added.
Thank you for your input.
It's something to consider for a next generation version maybe...or for someone considering following in these well laid out footsteps.
Nicely done project and looking forward to seeing what happens to the CRT. :)
:D
