Step 9Rectangular keys
Then I marked the exact size of the buttons on the styrene and cut it with scissors. Anyway, I found this neat profile at the hobby shop and made the edge of the buttons with it. Use special styrene glue. These look quite right with the round buttons. Slightly sand the corners to round them and on to the spray both to apply a couple layers of metal silver.
Finally cut the printout and glue the pieces in. With this, the basic keyboard is done. At this point you might want to try every key if it works properly. If it has a tendency to jam, remove the key gently from the keyboard and inspect the stem. Maybe you marred it after all and there is a burr left; remove it with an X-Acto. Or a piece of dirt is stuck to the stem. Also check the hole. Use a little bit of graphite dust, cross your fingers and put the key back in. Good luck my friend!
The rest is more or less left to your fantasy.
comments
Add Comment
MissBetsy (author)
says:
MissBetsy (author)
says:
Add Comment
