Miss La Sen Lantern
236
Posted in CraftPaper
Introduction: Miss La Sen Lantern
Miss La Sen is a fictional character in boardgame, comic books, cartoon clips and Miss La Sen spring roll etc... With this guide, you can make a Miss La Sen lantern easily.
Step 1: Download This Pattern and Print It Out in A2 Size Paper. You Can Print It Directly on the Cardboard.
Step 2: You Can Print It Out on the Cardboard or on the Normal Paper, Then You Can Glue It on the Cardboard.
Cut out 2 Miss La Sen sides.
Step 3: Cut the Bracket Like the Picture.
Step 4: Cut the Glass Paper and Use the Glue-gun to Glue It Onto the 2 Sides of Miss La Sen.
Step 5: The Side of Miss La Sen After Glueing
Step 6: The 2 Sides of Miss La Sen After Glueing the Glass Paper.
Step 7: Roll the Bracket Into the Round, Glue 2 Ends of the Bracket Together.
You can punch a hole on this bracket to insert the small electric light at the top of the lantern.
Step 8: Glue the Arrows on the Brackets Onto the First Miss La Sen Side or You Can Punch the Holes and Insert the Arrows in the Holes.
Step 9: Glue the Second Miss La Sen Side Onto the Arrows on the Brackets.
Step 10: 2 Sides of Miss La Sen Are Connected to the Bracket.
Step 11: Use a Red Tassel
Step 12: Add the Red Tassel at the Bottom of the Lantern.
Step 13: You Can Use the Paper Sheet to Connect at the Top of the 2 Sides of Miss La Sen Together.
Use a string to tie at the top of the lantern. Take a bar to tie the top and hold it.
Step 14: If You Want to Make the Lantern With the Discrete Elements, You Can Use This Pattern. Trace Them on the Foam and Cut, Then Glue Them Together.
Download this pattern and print it in A2 size paper.
Step 15: You Can Make Miss La Sen Rooster Lantern With This Pattern.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
