Miss La Sen Lotus Triangle Bottom Lantern
Published
Introduction: Miss La Sen Lotus Triangle Bottom Lantern
You have the lotus lantern with 2 layers, 6 petals. It is very simple
Step 1: Download This Pattern. Print It in A2 Size Paper.
Step 2: Trace on the Art Paper or Foam. Cut the First Layer and the Second Layer.
Step 3: Punch 3 Holes on Each Layer to Insert the Arrows Like the Picture.
Step 4: Use the Glass Paper to Glue on Each Layer.
Step 5: Insert the Arrows Into the Holes
Step 6: Use the Zinc String to Insert Into the Bottom of the First Layer.
Step 7: Insert the Zinc String Into the Bottom of the Second Layer
Step 8: Cut the Excess String
Step 9: Punch the Holes on the Top of Each Petal for the Second Layer
Step 10: You Should Insert the Arrows Inside Like the Picture. It Is More Beautiful.
Step 11: Use the String to Insert Into the Holes on the Top and Tie Them Together.
Step 12: You Can Cut the Top Bracket to Insert Into the Holes on 3 Petals of Second Layer.
Step 13: Cut the Sepal to Glue Under the Lotus Lantern.
Step 14: Download the Pattern for Miss La Sen Shape. Cut the Elements and Glue Them Together. Put Miss La Sen Under the Lantern
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
