Step 7The Science Bit
Alka Seltza contains two important ingredients: an acid and a carbonate.
The acid is citric acid (the stuff that give citrus fuits their bite), and the carbonate is "bicarb" - sodium hydrogen carbonate. Both of these are solids, and don't react together.
Add water, though, and they dissolve. This gives them the freedom to react, and they produce sodium citrate and carbon dioxide. Carbon dioxide, being a gas, has a much larger volume than the original reactants. Trapping the gas provides the pressure needed to work the A-S rocket.
So, why does a matchhead make a good rocket fuel? The reason is that it carries both the fuel and the oxygen required to burn it, and the products are gaseous and are ejected forcibly from the end.
There are two kinds of friction match, the "strike anywhere" match and the safety match.
Consider the "strike anywhere" match. These are manufactured by dipping one end of a bare wooden stick into a fireproofing agent, so that it will not burn too readily. The other end is coated with paraffin, a hydrocarbon. The head of the match contains an oxidising agent, such as potassium chlorate; and a substance that is easily oxidised - usually sulphur. The head also contains a filler of clay; a binding material, such as glue; and dye to give it a distinctive colour. At the very tip is a small amount of phosphorus trisulphide, which decomposes and burns at a low temperature. This ignites the paraffin, which burns more readily because of the presence of the other chemicals. The products of combustion therefore include sulphur dioxide gas and carbon dioxide gas, which occupy very large volumes compared to the solid reactants.
10
comments
Add Comment
Kiteman (author)
says:
Kiteman (author)
says:
Kiteman (author)
says:
Add Comment
