3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mobile Car Computer
Mobile Car Computer
This is a personal computer which can use in the car with all the features,and performance.
Specially this PC has works with Automobile power supply.(12V DC) It has 7inche LCD TFT monitor with VGA input.And Its touch sensitive display.I have attached a Touch sensitive Panel for 7 inch display.So no use of Mouse or Keyboard.Because Its fully touch sensitive.Its really like an i pad :D :)
And a lot parts I have bought from Ebay and local shops in here.
Its Intergraded with Bluetooth,and it has USB remote controller for control all things.
Enclosure was design and made by myself.(its aluminum)
Still trying to attach a GPS for my car computer.
It has a Special function.It can display a vehicle current running details of Vehicle Engine details like ( Engine RPM,acceleration,Engine temperature,Water temperature,errors and troubles in engine,etc)
And If you are a doing Motor Sports or if you have any custom ECU in your car like GEMS,Motec,AEM,Greddy Racing ECU's.you can easily connect with your ECU through the USB or RS232 and can Tune your ECU as you want.Because you want anymore your LAPTOP or other PC.If can attach like this PC in your Car really can have a nice easy time. :)
Intel 1.6 Ghz Atom,1GB of DDR2 Memory,Intel Graphics chipset945,4 USB Ports external,2-PS2/Mouse/Keyboard,1-Paralell printer port,1-Serial Port,1-Audio Out,1-Audio Line Input,1-Microphone Input,160GB Hard Drive,Windows XP or Windows 7 x86,Automotive Power inputs with Input Power -12v
**7 inches HD TFT LCD Monitor/TV Touch Sensitive(no need of a mouse)**
BUY NEW CAR COMPUTER FOR CHEAP PRICE : http://www.ebay.com/itm/270948703846?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_2455wt_1265
Step 1Colellect all items and parts
Intel Atom mother board(built in on board CPU,On board sounds,on board VGA)
1GB Ram Kingston
USB IR PC remote controller
12V DC to ATX Mini power Supply (90Watts)
160GB IDE Laptop grade hard drive
2.5" IDE to 3.5" IDE converter
Make your PC enclosure (10"x9.5"x2.8" aluminum)
25A fuse for power line
High gauge wire for positive and negative power connectors
7" LCD TFT monitor
7" touch panel with USB touch controller for make your Monitor touch sensitive
OBD II to USB cable for read your vehicle running data(ELM 327 cable)
find portable USB CD/DVD Drive for install your OS (XP or win7)
22 comments
Jan 1, 2011. 12:50 PMac1D says:
The hardest part is to install it properly hidden in your car!
Nice instructables, I was planning on doing this soon. I was planning on using an laptop, as I had no idea there was special case/powersupply for car!
Aug 7, 2011. 9:54 AMwill0282 says:
Thanks for these links...i already have a carpc that i built from scratch, i wish i woulda have use the spare laptop i have at home. I know it woulda have worked because i tested out all the software there before anything...i well, i guess for the next car.
Jan 9, 2011. 7:08 PMzack247 says:
very cool. when i get my license something like this is going in my car :D
Apr 22, 2011. 10:07 PMzack247 says:
im going to attack a general PSU and see if i can find the parts to make a 12v to ATX converter, if those -12v and -5v werent necessary i could easily do it :P
im getting a car next year, i have already started getting the parts for this, im gonna try to fit a 15" LCD monitor into it.
Apr 23, 2011. 10:48 AMzack247 says:
the 15" LCD can be run right off the cars 12v line, i have found the pinouts fro the main control boards power connections, al i need to do now is find some white LEDs or something to replace the backlight bulbs, the inverter never worked on the screen anyway.
i think i might get a VGA to Composite connector for both the pc and the screen, that way i wouldnt have to route such a thick VGA cable, would that work?
i also want to know, how many cores does your Atom have?
Feb 4, 2011. 2:24 PMespdp2 says:
Not Windows!! You'll crash!!!
Feb 6, 2011. 4:21 PMespdp2 says:
Nicely executed project. This is why I love this site.
I'm just kidding. I've had enough experience with Windows BSOD, though.
Apr 22, 2011. 10:05 PMzack247 says:
well so long as you have it set up with the right amount of ram and processor power (and maybe the right wattage PSU, these are a real problem), you shouldnt run into it
Dec 31, 2010. 12:58 PMRednecknerd says:
Nice work.
To add gps, use a usb bluetooth dongle.
I picked one up locale for $5, but they are all over the web
http://tinyurl.com/38v6anu
Then use a bluetooth gps. I have one of these.
http://www.pocketgpsworld.com/globalsat-bt-328-gps-review.php
I paid about $35. Charges from car.
Jan 4, 2011. 6:57 AMRednecknerd says:
Back when I used my laptop for nav I had Microsoft streets and trips. I also tried delorme, but it didn't use moving maps at that time. Moving maps are essential for nav in my opinion.
There are many free options but they generally require you to make your own maps.
Jan 4, 2011. 9:32 AMRednecknerd says:
http://www.mapcruzin.com/free-sri-lanka-maps.htm
This might help.
Jan 4, 2011. 12:20 PMRednecknerd says:
http://gpsunderground.com/
I think these guys can help you better than me.
So far I haven't found a free alternative to using google maps or a program to download them for you.
It would be a long process to manually save a large enough area of google maps to be usefull.
Dec 31, 2010. 10:08 AMAdam Manick says:
Great work! 5 stars
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:slwthr
