Specially this PC has works with Automobile power supply.(12V DC) It has 7inche LCD TFT monitor with VGA input.And Its touch sensitive display.I have attached a Touch sensitive Panel for 7 inch display.So no use of Mouse or Keyboard.Because Its fully touch sensitive.Its really like an i pad :D :)
And a lot parts I have bought from Ebay and local shops in here.
Its Intergraded with Bluetooth,and it has USB remote controller for control all things.
Enclosure was design and made by myself.(its aluminum)
Still trying to attach a GPS for my car computer.
It has a Special function.It can display a vehicle current running details of Vehicle Engine details like ( Engine RPM,acceleration,Engine temperature,Water temperature,errors and troubles in engine,etc)
And If you are a doing Motor Sports or if you have any custom ECU in your car like GEMS,Motec,AEM,Greddy Racing ECU's.you can easily connect with your ECU through the USB or RS232 and can Tune your ECU as you want.Because you want anymore your LAPTOP or other PC.If can attach like this PC in your Car really can have a nice easy time. :)
Intel 1.6 Ghz Atom,1GB of DDR2 Memory,Intel Graphics chipset945,4 USB Ports external,2-PS2/Mouse/Keyboard,1-Paralell printer port,1-Serial Port,1-Audio Out,1-Audio Line Input,1-Microphone Input,160GB Hard Drive,Windows XP or Windows 7 x86,Automotive Power inputs with Input Power -12v
**7 inches HD TFT LCD Monitor/TV Touch Sensitive(no need of a mouse)**
Remove these ads by
Signing UpStep 1: Colellect all items and parts
1GB Ram Kingston
USB IR PC remote controller
12V DC to ATX Mini power Supply (90Watts)
160GB IDE Laptop grade hard drive
2.5" IDE to 3.5" IDE converter
Make your PC enclosure (10"x9.5"x2.8" aluminum)
25A fuse for power line
High gauge wire for positive and negative power connectors
7" LCD TFT monitor
7" touch panel with USB touch controller for make your Monitor touch sensitive
OBD II to USB cable for read your vehicle running data(ELM 327 cable)
find portable USB CD/DVD Drive for install your OS (XP or win7)
Visit Our Store »
Go Pro Today »
Nice instructables, I was planning on doing this soon. I was planning on using an laptop, as I had no idea there was special case/powersupply for car!
And if you want to use your laptop in car use car power aapter for th laptop : http://cgi.ebay.com/CAR-DC-POWER-ADAPTER-supply-HP-Pavilion-Laptop-NEW-/110576563166?pt=LH_DefaultDomain_0&hash=item19bee073de
I have used 12V DC ATX mini power supply,you can buy it from ebay.
Here is the link: http://cgi.ebay.com/PW-200-M-200W-DC-DC-Mini-ITX-ATX-12V-Power-Supply-PSU-/120657459651?pt=PCA_UPS&hash=item1c17beb9c3
im getting a car next year, i have already started getting the parts for this, im gonna try to fit a 15" LCD monitor into it.
If you are using 15" LCD i think you should fix a little high wattage 12v to ATX converter.
here is the link : http://cgi.ebay.com/2010-12v-200w-DC-DC-ATX-24-Pin-Power-Supply-Mini-PC-/250795532232?pt=PCA_UPS&hash=item3a64941fc8
Cheers!
i think i might get a VGA to Composite connector for both the pc and the screen, that way i wouldnt have to route such a thick VGA cable, would that work?
i also want to know, how many cores does your Atom have?
To add gps, use a usb bluetooth dongle.
I picked one up locale for $5, but they are all over the web
http://tinyurl.com/38v6anu
Then use a bluetooth gps. I have one of these.
http://www.pocketgpsworld.com/globalsat-bt-328-gps-review.php
I paid about $35. Charges from car.
There are many free options but they generally require you to make your own maps.
This might help.
Do you know any way to download the GPS map file from car Navigation GPS unit?
I think these guys can help you better than me.
So far I haven't found a free alternative to using google maps or a program to download them for you.
It would be a long process to manually save a large enough area of google maps to be usefull.
