Mobile Charging for Laptop, Tablet, and Phones.
Introduction: Mobile Charging for Laptop, Tablet, and Phones.
Many times I am on the go and my phone is on low battery. Or I might be traveling long distances and need to charge my laptop for later. This instructables shows you how to power your electronics on the go in a very green way.
Step 1: Materials
Before you buy any materials you want to know how much voltage you want for your battery, inverter, and electronic. For example, I have a 12v battery and an inverter that needs an input of 12v. The output of my inverter is 110-120v which is the same amount of power I need to charge my laptop. 1) Deep Cycle Battery from (Deep cycle means rechargeable) 2) Inverter from (Try to have one that has an adapter on it) 3) Battery Leads from (have an adapter the same one that is one the inverter) Optional: Case/ enclosure for all the parts to be in.
Step 2: Creating the Circuit
Connect the battery leads to the deep cycle battery. Positive to positive and negative to negative. Then connect the adapter from the inverter to the adapter from the battery leads.
Step 3: Conclusion
One of the downsides to this is that it's bulky and the battery is a bit heavy so it is smart to put it in an enclosure. You can also use small appliances while the power is out. To be very environmentally friendly you can add on a solar panel or a motor attached to a bike to recharge the battery.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    I know, older post, but why go from 12v to 110/220? you also can attach a car cigarette lighter to the battery and use a 12v usb charger. that way there is way less current being lost. you'll last longer.
    I like this idea. How many times can it charge a laptop or phone at full charge?
    The battery has about 12Ah which means it can operate at a constant output for 12 hours. Of course it doesn't last for 12 hours though and when it's low I use a solar panel to recharge it since its a deep cycle battery.
    Very cool. I might give this a try. ABout how long does it take to charge using solar energy
    I'm not entirely sure because I haven't gotten the solar panel yet. But I would expect to leave the solar panel out in the sun for about 2 hours and see how much that charges.
