Mobile Control LED(Arduino+Bluetooth Module)
Published
Introduction: Mobile Control LED(Arduino+Bluetooth Module)
About: Likes to build circuits, electronics project in free time... Also love coding...have knowledge of JAVA, C, C++, Arduino, HTML, Android Studio, LabView, CoDeSys, OrCAD.....
Hello,
In this instructable i will show how to control LED from Android phone using Arduino Uno Board and HC-05 Bluetooth module.
In this Arduino code is explained.
For Android code refer...
https://www.instructables.com/id/App-for-Mobile-Control-LEDArduinoBluetooth-Module
Step 1: Requirements
Hardware:
  • Arduino Uno board
  • Bluetooth Module(here HC-05)
  • LED
  • Male to Male wires
  • breadboard
  • Android Phone
Software
  • Arduino
Step 2: Circuit
Make circuit as shown in diagram above.
Note: connect VCC and GND of bluetooth module to 5V and GND of Arduino respectively.
Step 3: Arduino Code
You can download code (led.ino file)
code is to turn ON ,turn OFF and adjust the brightness of LED.
boolean led= false;
char command;
String string;
  void setup()
    Serial.begin(9600);
    pinMode(6, OUTPUT);//connect led to pin 6
  void loop()
    if (Serial.available() > 0) //check for input data
    {string = "";}
    while(Serial.available() > 0)
      command = ((byte)Serial.read());
      if(command == ':')
        break;
      else
        string += command;
      delay(3);
    if(string == "on")//as "on" is written in android app for turning on led
       analogWrite(6, 255);
       delay(10);
       Serial.println(string);
       led = true;
    if(string =="off")//as "off" is written in android app for turning on led
         analogWrite(6, 0);
         delay(10);
         led = false;
    if ((string.toInt()>=0)&&(string.toInt()<=255))
      if (led==true)
        analogWrite(6, string.toInt());//type casting to integer
        Serial.println(string);//printing the int value
        delay(10);
Step 4: Android App
Download the LED Control.apk from link given:
https://drive.google.com/open?id=0B4eY-jcXDOueX0M5...
  • Install the app
  • upload the code in Arduino (NOTE:keep recieving pin of arduino disconnected while uploading code)
  • OPen the app and enjoy controlling LED from mobile
If want to learn Android app code refer...
thank you.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    2 Comments
