3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mobile Stripper Pole (no need to attach to ceiling)
Step 2Stripper pole assembly
stripper pole assembly
Stripper Pole Assembly
# Drill 4 holes in the center of one of the plywood panels and the 1' piece of 2"x6" for the flange to get bolted onto.
# Bolt the flange onto the 1' 2"x6" and the plywood panel panel with the bolts coming up through the bottom, so that the nuts get tightened on to the flange, and put washers between the head of the bolt and the plywood to keep the bolts from pulling through the wood (see figure 2). From the bottom up the sandwich should look like this: heads of bolts, washers, bottom of plywood, 2"x6", flange, nuts, tails of bolts.
# Nail the two 4' long 2"x6" onto the bottom piece of plywood (the one with the flange attached). Put them at the edge of the plywood and on opposite sides.
# Nail the two 1 1/2' long 2"x6" in the middle of the plywood as in the figures. They should butt up against the 1' piece of 2"x6", although they are standing tall, and it is lying on its side.
# Now cut a hole in the exact center of the other piece of plywood the same diameter as the pole. You can do this with a special drill bit made to cut holes or you can just keep drilling holes in a cirlce till the middle falls out.
# Finally, nail the top piece of plywood with the hole in it onto the 2"x6" so that it matches up over the bottom plywood.
# Screw the pole into the flange.
# Put the bricks into the openings on the side to weigh down the base. The farther towards the edge the bricks are the better leverage they'll get to weigh down the base.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wakeupsilver
I'm not really about me.
