Mobile Dog Food Bin
3,998
119
Posted
Introduction: Mobile Dog Food Bin
Rather than having to carry around large bags of dog food at feeding times, make this mobile dog food storage bin. It is big enough to hold an 8kg bag of dog food, yet small enough to store in a tight place. The castor wheels and handle on the side allow you to move the dog food bin around with ease.
YOU WILL NEED:
2 of 450 x 500mm 16mm supawood – front + back
2 of 150 x 500mm – 16mm supawood – sides
2 of 182 x 450mm – 16mm supawood – top + bottom
4 castors
1 handle and screws
2 overlay hinges and 16mm screws
40 x 30mm cut screws
Alcolin wood glue
TOOLS:
Drill / Driver + assorted bits
Countersink bit
Orbital sander + 180-grit sanding pads
Optional: Corner clamps
Step 1: Assemble the Box
1. On both the front and back, use one of the side sections to draw a pencil line along the side edge. This line will guide you when drilling pilot holes for mounting the side sections.
2. At 50cm in from the top and bottom, drill and countersink 3mm pilot holes.
GOOD TO KNOW: The countersunk holes should be slightly larger than the size of the screwhead that you are using to join the sections together.
3. Use corner clamps to hold the front/back and sides in place while you drill pilot holes into the edges of the side sections.
4. Secure the front/back to the sides using 4 x 30mm screws.
5. Pop the base inside the frame. Drill pilot holes through the front/back and sides into the base. Countersink all holes before securing with 4 x 30mm screws.
Step 2: Finish the Box
6. Sand all the edges smooth with 180-grit sandpaper and then apply a thin layer of wood glue over the cut edges. This helps seal the edges before painting.
7. Fill all screw holes with wood filler and let this dry before sanding smooth with 180-grit sandpaper. Wipe clean.
8. Take the box outdoors and place on newspaper. Spray on 2 light even coats of Rust-Oleum 2X in your choice of colour. Allow the first coat to dry before applying the second coat.
GOOD TO KNOW: Last image shows an edge that was not coated with wood glue. You can clearly see how the paint is absorbed.
Step 3: Attach the Lid, Handles and Castors
9. Attach hinges to the underside of the top using 16mm screws. Click here for instructions on how to mount an overlay hinge.
10. Transfer the measurements for the mounted hinges onto the top of the back section and secure the hinges in place.
11. The handle is mounted onto the side section of the box. Measure and mark for placement and drill a hole for the mounting screws to secure the handle.
12. Mount the castor wheels to the base of the unit.
This project was brought to you by www.easyDIY.co.za.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
4 Comments
Very nice! I have a bunch of rolling plastic bins that are starting to break and these will work better. And look nicer too. We have a bunch of rescues! Thanks!
Great idea. Only thing I see wrong is the choice of materials. Supawood is MDF and MDF is EXTREMELY POISONOUS!! It has been known to cause cancer and other bad things. I would use sanded plywood or something like it. Good job on the project and the 'ible
great idea! we recommend that the dog food remain stored in it's bag, for many reasons:1) the oils do not transfer to a plastic bin that never gets cleaned, 2) important manufacturing information concerning the individual lot, 3) serving info should something happen to the owner.
Very nice! Those bags are so heavy all the time!
