Mobile Phone Scooter Clip
16,934
41
Posted in WorkshopMotorcycles
Introduction: Mobile Phone Scooter Clip
I wanted a convenient and safe method to attach my mobile phone to my scooter, so that I can see who's calling my bluetooth earphone, see GPS guidance etc. Of coarse, you should NEVER operate your mobile phone while riding!
Step 1: I Bought a Simple Cheap Holder for Around 8$
Then cut the upper part of it, using a knife and a hammer to knock it (without the hammer it would take me hours).
Step 2: Measure and Mark the Exact Point of the Screws
In my scooter model (Piaggio Xevo) the plastic cover of the handlebar is convex, so I had to be accurate.
Drill 3 holes (this is the optimal number for strength and stability, you can drill less or more if you want).
Then drill the upper part with a wider drill, so the screw head will be all covered. You might need to grind the screw head so the profile will be flat.
Step 3:
Dissemble the plastic cover of the handlebar. Mark the exact point and drill in it. You may want to drill with a narrow drill first, and only then widen it - this will lead to more accurate results.
Step 4: Cut an Old Bicycle Tube
Cut to shape 3 rubber pads. You can cut more or less as this will affect the tightening - more pads will allow stronger tightening.
Assemble the whole pieces according to this order:
- Plastic clip
- 3 Rubber pads
- Handlebar cover
- washer
- Nut
Tighten it all and...
Step 5: Have Fun!
During the firsts few rides my recommendation is to secure your mobile phone with a cord, just in case anything goes wrong... After 2-3 hours of riding check the tightness of the bolts and tighten if necessary.
Drive safe!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    3 Comments
    This is a great idea. I'm going to try work something around for mine. A very different model so it may need its own Instructable. This sure beats the packing tape on the headlight I've been using till now.
    not a bad idea but can use some better parts like lock nuts or use lock tight wire in a power cable or usb port use the rubber on both sides to secure the nuts better and reduce stress on the plastic
    Thank you,
    I totally agree about the lock-nuts - in the long term that might prevent loosening of the nuts. Nevertheless, I've been using it daily for more than a month now and it's still very stable. Moreover - if it does get's loose, it won't fall right away because the screws are relatively long.
    There is no stress on the plastic because it's very strong.
