3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mod Your 5G Video iPod With Internal Bluetooth
Here's the long awaited 5G Video version of my iPod BT Mod! If you're tired of the headphone cord? We've all seen iPods die an early death because someone got their cord tangled up while on the treadmill or something and the iPod goes flying!
Sure you can buy a $50 BT adapter and plug it into the dock connector. But what if you wanted an integrated, OEM-like solution? Something that on the outside would look like it came from the factory, like Apple should have done?
Follow along and don't forget to check www.iPodHackers.net for more details and info on other iPod hacks!
You might also want to check out my first iPod BT Instructablebefore you start on this one.
For Sale on eBay! I'm selling one of these babies on eBay so if you don't want to build your own, here's your chance to own it! Click Here for Link
Step 1Materials and Tools
Materials and Tools
Ideally, you will need the following items:
Small Phillips Driver
Small Flat Screw Driver
Plastic iPod Opening Tool
One or two 3mm LEDs
Xacto Knife or Razor Blade
Compact Flash to 1.8" ZIF IDE adapter. Get it from Tarkan
Fully ATA compatible Compact Flash Card (2Gb min). I've had good luck with Transcend, Sandisk and Adata but others may work as well.
5th Generation iPod Video. If you use an iPod with a bad drive, just make sure that the unit is otherwise fully functional.
Drill and small drill bit (optional)
Bluetooth headphones (A2DP)
Universal Bluetooth Adapter*
68 comments
1-40 of 68next »
Dec 4, 2011. 8:00 AMmitchellhacks says:
Will This Effect My Jailbreak
Mar 10, 2008. 9:35 AMDurtyBunny says:
How does using the BT impact the battery life of the iPod?
Aug 3, 2010. 4:45 PMSmokabowl says:
and if you are using CF you should have the room for a hi cap LI POLY battery from the 4g series. Which would give you about a 370% increase in battery life + CF = 400%. http://eshop.macsales.com/item/Newer%20Technology/BIPOD1350MPH/
Jul 18, 2011. 7:52 AMhakeem42020 says:
are you sure these work in the 5g ipods
Jun 7, 2011. 10:47 AMMikkun says:
do you still remember the model number of this bluetooth module?
Jun 4, 2011. 9:11 PMhakeem43020 says:
Does this work with the new ipod classics?
Nov 7, 2010. 11:56 AMKristyanna1019 says:
look at the last slide before this there are three. the blue wire is audio ground.
Sep 9, 2010. 4:05 PMGENERALCHAOS says:
ur link is dead
Aug 11, 2010. 11:24 AMSmokabowl says:
Everything you need, is here people http://pinouts.ru/PortableDevices/ipod_pinout.shtml
Mar 25, 2008. 12:25 PMcotton says:
my broter puled my clam shel ipod shuffle out while sinking and killed it i got it to work againand i hate the updated firmware
Aug 6, 2010. 11:19 AMSmokabowl says:
The ground goes to the frame doesn't it always? As far as the actual DC+ all you need is a multimeter, a new battery in your ipod, and some patience.
Feb 7, 2010. 9:44 PMmat314kid says:
Can you please tell me where the power and ground go to? I have my board all wired up, have completed the flash card upgrade, just finished tribooting IPL, RockBox and the Original FW. All I need now is to know where to solder the power and ground because I can't find my multimeter anywhere and really don't have the money to go spend $30+ on a new one.
May 15, 2009. 6:03 PMwvufan8866 says:
where does the ground for the audio go to on the ipod? and where do the ground and power go to on the ipod that were on the top right of the bluetooth mb?
Nov 21, 2009. 1:58 PMpledpfldfpldfp says:
I second this request. This guide is useless because it leaves out these 2 critical steps. They show you disassembly, reassembly, but leave out where you actually solder the bluetooth power and audio wires. PLEASE FIX THIS GUIDE. IT IS USELESS IN IT'S CURRENT STATE!!
Nov 18, 2009. 8:37 AMMike8913 says:
 does this enable you to sync with your computer via BT?
Jul 25, 2009. 10:25 PMRobert.Springer says:
Hey, I am looking at modding either a 5G or 4G ipod with the compactflash internal ssd and then adding a FM transmitter. My problem is though that I can not find the internal voltage that the ipod runs on anywhere on the internet. I need this because as I have the larger version of both these ipods I wish to add an internal fm transmitter (belkin tunecast 1 or equivalent) for use in the car. I know that most electronic devices run at 5v and was wondering if the ipod has a dc-dc transformer in it to transfer the voltage from the 3.7v lithium cell. Am I right to assume that the dc-dc converter only turn on when the ipod is on? If so I will just use a voltage divider to supply my 3v input for the FM transmitter. Any help would be greatly appreciated. Robert Springer
May 15, 2009. 6:39 PMMaltiK says:
Must use up to 50% more power... so you will need to tether this baby, which will make the fact that its bluetooth kind of useless... because your wiring it up.
Jul 23, 2008. 12:00 AMpotato413 says:
how much are the clear front panels and where do you buy them?
Mar 3, 2009. 1:17 AMipodmodder says:
For a 5th gen video they're only 10 bucks with a tool kit and everything else you need.
get em at http://www.rapidrepair.com/shop/ivue-ipod-crystal-case.html
just be warned, if you live outside of the us, they only ship international priority so you'll end up spending 30 bucks on shipping.
Mar 10, 2008. 3:45 PMjoly says:
Really good tutorial! I might try it! but what do you mean by : CF card fully ATA compliant
Mar 18, 2008. 10:47 AMDerin says:
or in other words:CF is fully IDE
May 3, 2008. 9:55 AMDerin says:
or sata
Jun 21, 2008. 3:03 AMDerin says:
no not sata sata dosnt have 50 pins(i counted)
Jul 18, 2008. 1:33 PMRedgerr says:
lol, thats a lot of counting :O
Jan 25, 2009. 7:50 PMlasalite says:
not really sata has only a few pins, less than 20 i think, ATA compliant means you arnt using some wierd SCSI, SATA, IDE, S-IDE, are all ATA
Aug 18, 2008. 1:08 PMbubbapod says:
where on the ipod motherboard can you tap into the positive and negative power from the battery on a 5th generation ipod?
Jun 12, 2008. 4:15 PMnrusnak says:
i would like to know what the hot glued wires are for? and because i do not see a place for the ground audio common where does it go?
Apr 2, 2008. 7:58 PMpmac93 says:
can you fit everything in it if you leave the hard drive in......it's pretty tight.....
May 31, 2008. 12:05 PMDerin says:
you can with the 60/80 gb backplate
Mar 22, 2008. 5:41 PMlightmoon1345 says:
Wouldn't the constant exposure to the bluetooth give me cancer? I usually keep my ipod in my pocket the entire time. Im thinking long-term, I'm 16. So I don't wanna die at 50 or 40.
May 29, 2008. 12:23 PMNetReaper says:
I think thats microwave radiation and cell phones, bluetooth isn't powerful like cell phones
Apr 5, 2008. 9:37 AMkonablue says:
not trying to rip on you in particular but to the general population...it drives me crazy when people say the higher number and then the lower number lol i.e. "50 or 40" or oh go put the cookies in for 15 or 10 minutes...its 10 OR 15 MINUTES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! AHHHHHHHHHH lol
Jul 9, 2008. 6:08 PMsurroundsound5000 says:
Have to agree. It just goes against grammatical convention. Just don't get me started on -Lack of capital letters -No space before ellipsis -Lack of quotation marks for direct speech -Overuse of exclamation marks -Etc -Etc Lol
Apr 8, 2008. 7:54 AMaltmaker says:
Sorry mate but its a difference of opinion. It may annoy you, but try venting it somewhere more appropriate.
Jul 18, 2008. 1:35 PMRedgerr says:
i agree, this is not the place to vent about it lol, but i do think that is lower to higher numbers.
Apr 8, 2008. 11:46 AMkonablue says:
I felt this was pretty appropriate considering this is a fun site for people and i thought I made it pretty clear it was a joke...I realize different people and places have different ways...lighten up
Mar 30, 2008. 10:45 AMzpersichetti says:
i dont think bluetooth gives you cancer
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:fstedie
Hello, my name is Eddie. I'm one of those people that can't leave well enough alone so I'll inevitably take things apart and modify them to suit my needs. As evidenced from my Instructables, I've b...
more »
