3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mod Your 5G Video iPod With Internal Bluetooth
Step 5Preparing the Bluetooth Module
There have been a lot of questions regarding the type of Bluetooth module used in this mod. Just about any universal module will work, some will be easier than others to wire up. Don't use a dock-based module, finding the correct connections in it will be extremely difficult.
Unlike my 4th Gen BT hack, here I used an older module from Billionton mainly due to its small size. Another difference between the two is that in the Jabra and others like it, you will need to either pair it before you close up the case or allow for a way to access the module's switch.
Prepare the BT module as shown and solder the power and audio terminals to the appropriate locations on the ipod. If you want a status LED, you'll want to solder leads to the SMT LED pads so that you can route your LED to the frame.
Notice that you will likely need to flatten the "bubble" part of the LED to make it fit into the frame without sticking out too much.
1 comment
Jun 7, 2011. 10:47 AMMikkun says:
do you still remember the model number of this bluetooth module?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:fstedie
Hello, my name is Eddie. I'm one of those people that can't leave well enough alone so I'll inevitably take things apart and modify them to suit my needs. As evidenced from my Instructables, I've b...
more »
