Mod a Ricochet radio modem to take an external antenna by Myself
Step 7: Solder the new jack into place.
Clean the iron tip by wiping it on the sponge. Get a bit of flux on the end of the solder, then touch it to the iron so a tiny droplet of solder clings to the iron.
Hold the jack in place with a toothpick, popsicle stick, or whatever. Touch the molten solder to the intersection of the jack and one ground pad. If there was flux on the pad, the solder should flow and make the connection. Remove the iron and check your work.
Repeat the process for the other ground pad, then for the signal pad. The rearmost ground pad, which was used for the H.FL connector, doesn't need to be used for the U.FL connector but I soldered it anyway.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
