Step 6Final Thoughts
You could possibly open up the back of the gun, and on the bottom of the circular piece of plastic that houses the green rotating drum, glue a nut around the hole on half of the plastic. This will allow you to attach a flashlight, dart container, tripod (for a mounted gun), etc.
You could also cut a few holes in the handle of the gun, put in a separate battery pack, and install white LEDs, a laser pointer (make sure you install a way to calibrate/adjust it)-although, it wouldn't be necessary the way it shoots (unless you've upped the voltage), or possibly install a back-up battery pack that re-routes the power to the motors by turning the original pack off, and the back up pack on.
There might possibly even be room on top of the gun for a scope or sighting device of some sort-but again, it might not be necessary. If you do mount anything on top, allow clearance for the front of the gun to swing around for reloading.
I strongly advise further mods, changes, add-ons, etc (unlike my dad). If anyone has anything (constructive) to say about this mod, gun, project, instructable, or anything in general, please leave a comment below!
Also, I did promise an illustration of me using this gun. Check it out.
![my modded nerf darts :]](http://img.instructables.com/files/deriv/FRQ/ZHTC/G5FRGGN3/FRQZHTCG5FRGGN3.SQUARE.jpg)
Ellis
