Mod a USB to TTL Serial Adapter (CP2102) to Program ESP8266
52,126
41
22
Posted
Introduction: Mod a USB to TTL Serial Adapter (CP2102) to Program ESP8266
This USB to TTL Serial board based on the CP2102 chip, it have no enough current (400mA+) to driven ESP8266. So I will fix the issue.
CP2102 Datasheet: https://www.sparkfun.com/datasheets/IC/cp2102.pdf
UPDATE: I made a new CP2102 USB to TTL converter depend on the board. It's now on tindie.
Step 1: Materials
  • 1 x CP2102 USB adapter, it's easy be found at eBay by keyword cp2102
  • 1 x AMS1117-3.3
  • A knife
  • A soldering iron
Step 2: Cutting Off the Original 3.3V Output
The 3.3V from CP2102 has only 200mA output. It's not enough for esp8266. I cutting off the 3.3V output with an knife.
Step 3: Soldering LDO AMS1117-3.3
Use the pin 5V as input of AMS1117, connect the output to 3.3V
Now the USB adapter can driven esp8266 directly.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
21 Comments
Hi!
Will it work on PL2303HX chip as well?
I'm using old Profilic PL2303 USB2TTL adapter with dual 3.3V and 5V outputs.
On 3.3V pin flashing ESP without external power is ok ;) Tested with ESP-01, ESP-12E, ESP-14 and LUA MCU Dev Board V3.
If you have only 5V output, so this mod can work. BR
Does old prolific driver work with Windows 10? Bought one and no any text on the chip, couldn't make it work yet :(
It is working, but with only one old Profilic driver ... drivers from Windows Update or automaticaly installed drivers doesn't work. (the exclamation mark in HW manager)
I've saved it for later use, here is link from my dropbox:
https://www.dropbox.com/s/5ddxoi44ads0435/Profilic...
Please don't forget to check it with antivirus SW before running it!
I've installed this many months ago, BR ;)
Thanks kubik256 your driver works fine.
Nice to hear ;) Best regards.
Interesting...
I didn't know I can draw enough current from the chip on 3.3v
I'll try.
Thanks!
did you find the ans ??
