Mod a toaster and have retro art toast for breakfast
Step 8Final words and a few advices
Use plain Aluminum or stainless steel only: do not used painted tin as I did for my cookie cutters as heat here would transfer paint or finishing on your meal!
Try to avoid elaborate shapes: details will not show up
The toaster makes the difference: the larger the heating resistance the more uniform the drawing will be; try smaller bread slices or larger prongs (and toaster)
When you are tired of a shape, just remove it and do another one.
A final one: you don't need a toaster at all: just lay the Aluminum shapes on a pan and put your bread slices on it or, even better, use a press toaster.
You can also print a slice of meat.
Buon appetito !
12 comments
Oct 11, 2010. 10:09 AMnathankilpin says:
lol works
Jul 26, 2010. 6:03 AMCrazySheep says:
I would come to your house JUST for the toast!! I'll try to get permission to do this XD
Dec 20, 2009. 9:34 AMRandomTeeVee says:
question:
wouldnt the aluminum sheet in which you used to make the print on the toast cause the toaster to explode or something since metal shouldnt be in the toaster?
thanks!
(btw this is awesome)
Feb 5, 2010. 4:13 AMnaruto the ninja13 says:
your thinking of microwaves you cant  put metal in thoose it messes it up, but for toasters the things that heat the toast are metal also toasters just heat so metal is okay in the toaster
Jun 9, 2010. 11:14 AMseabananers says:
yeah in a microwave it some sort of magnetic waves or somethin
Jun 13, 2010. 7:38 AMbuilder968 says:
If you put aluminum in the microwave, you see sparks and bolts of electricity dance across the foil, melting the metal. If you leave this going on for too long, the bolts will get bigger and bigger- until, finally, it blows up in your face, your kitchen is on fire, and you're in the hospital being treated for burns and shock.
Jun 9, 2010. 8:19 PMSenior Waffleman says:
its called a microwave because it uses microwaves to heat up anything in there
Sep 30, 2011. 4:13 PMMatthewEnderle says:
It's called a microwave because it uses microwaves to accelerate the little tiny water particle in an object. The more water > the more heat due to friction. So a microwave will not heat anything up alone.
Jan 21, 2010. 2:44 PMkenexinator says:
(looks in toaster) there seems like a lotta metal in my toaster ....
Jan 21, 2010. 2:38 PMkenexinator says:
(looks in toaster) i dont know but there's a whole lotta metal in my toaster
Mar 15, 2010. 1:07 PMJonnyDude2008 says:
This looks great! I was wondering could this be done with regular household tin foil?
Mar 8, 2010. 9:41 PMYong2010 says:
Very Cool!!
Oct 15, 2009. 6:55 PMcvill says:
This is more hard core!
There is a guy in japan who makes art on his toast. Uses aluminum foiland an oven toaster though.
May 4, 2007. 8:29 PMPENIX says:
I think most mode I see are stupid, but this one is a definite exception.
Sep 12, 2009. 2:38 PMadnimo says:
But eh.. you only get half a toast...
Sep 12, 2009. 3:13 PMmiiwii3 says:
not unless you put the sheet on both sides
Sep 12, 2009. 2:39 PMadnimo says:
Using thinner aluminum you should be able to get a better toast, albeit less clear finish but a better toast nonetheless, which is why you're toasting the bread to begin with.
Feb 16, 2009. 3:09 AMm1n1j1mmy says:
awesome 10/10 mine was a eeyore lol
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:5Volt
