Remove these ads by
Signing UpStep 1Parts list and Tools
1 - 1-9/16" length of .04" (or 1MM) carbon fiber rod
2 - 1x3x1 ball bearings (item Code m021 from http://www.precisionheli.com)
1 - Picoo-Z mini Helicopter
The tools required are;
X-acto knife
small dental pick
a standard (flat end) screwdriver
a pair of locking needle nose pliers
a pair of diagonal wire strippers
1/8" drill bit
a large flat washer (I cut a small 1/8" deep slot in it to help remove the rotor)
Foam Safe CA glue
and a good magnifying glass will help too
Great mod for this mini helicopter. I think the 2 channels are becoming obsolete to the newer 3 channel indoor helicopter. Does anyone know of any good mods for the newer 3 channel helicopter?
A little tip for new owners:
If your heli doesn't go forward enough just gently twist the tail CW (tail facing you)if it's going to fast do the opposite and tweek it CCW. Leave the weights off until you know how it will respond. I added one weight at a time, one slightly more forward then the other for a total of 2.
I've got over 240 flight minutes on mine and still going strong. Only problem was this morning I couldn't get it to trim out (spinning CCW). After checking for dirt/lint I wound up replacing the tail blade. I'm going to assume that the hole wore out and the blade was slipping cause it works just like new now.
To see my other heli's and less successful endeavors goto:
Nidshouse
Happy flying!
