Step 2Opening up the body
Next start cutting through the seam that runs all the way around the copter holding the 2 halves of the body together. I started at the the back where the tail rotor arm runs into the body (less delicate stuff in this area). Once you get it started you can pry it open slightly, so that you can see what you are doing, (to stay away from the wiring and battery, to get the two halves separated all the way around.
Once I had this done, (see 2nd pictures), I switched it on and ran the copter at low speed to makes sure I hadn't broken anythings up to this point.
NOTE: From the 2nd picture you can see why a push-pin (mod to add weight) in the nose of the copter could be a bad idea. It's close to the battery compartment, and a crash could drive the pin into the battery.
Add Comment
